Pre-emission vs. Post-emission
Discussion in 'Ask An Owner Operator' started by Still Glidin', May 14, 2020.
  1. Still Glidin'
    Still Glidin' Bobtail Member
    6
    May 14, 2020
    Looking at buying my next used truck. Trying to decide on pre-emission vs. post-emission.
    Personally, I like the older pre-emission engines, but I've noticed lots of people complaining about leaking manifolds on the Detroit 60 series and CAT engines. Does anyone know if there was an issue with these engines that caused the manifolds to leak/break so often? I sure hope manufacturers have solved the leaking manifold problem on modern engines. Anyone know if modern engines chew through manifolds like the Cats and Detroit 60s did? I'm tired of replacing manifolds, but I sure do love those old-school engines.
  3. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    I haven't had to replace the manifold on my E model in the 3 1/2 years I've owned it. I haven't seen them being a recurring problem on here anywhere but thats don't mean anything I guess.
  4. Swine hauler
    Swine hauler Medium Load Member
    349
    2,245
    Jun 21, 2019
    I've got almost a million miles exactly on my series 60, put a set of bearings in it about six months ago. Never done anything else to it except for regular overheads.
    Manifolds?? Never give them a thought.
    singlescrewshaker Thanks this.
  5. terryt
    terryt Heavy Load Member
    736
    777
    Apr 27, 2009
    You only see and hear of problems on the internet. The rest us keep trucking 3 1/2 years on 60 series only one broken exhaust manifold stud very common on all engines. People put to much into internet rating's cause you never hear from the thousand and thousand of the trouble free trucks. Beside it still cheaper to repair the old one then the cost of an emissions engine.
  6. SmallPackage
    5,777
    18,542
    Dec 20, 2019
    Marion Texas
    Manifolds cracking or breaking isn’t the problem I know about. It’s the bolts get weak and stuck in the head and can break off due to the constant heat cycles. But thats been going on with every engine since the beginning of time.
    As for pre-emission engines. 100% for me as long as they are still able to run on diesel and the country is still free to do so!
  7. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
    The center section will burn out on a Detroit, just replace it with a one piece aftermarket, bully dog, full tilt,psi, plus others.
    Turbo $700, verses $5000, zero dollars for emissions or 10 to 20 to maybe fix emissions system. Plus a great reaso to not go to California,.
    Pre emissions wins every time
  8. blairandgretchen
    13,926
    76,511
    Dec 9, 2011
    South west Missouri
    What he said.
    I went with a one piece manifold - and threw a BW turbo on at the same time.
    I’m a pre 2004 fan.
  9. mover man
    mover man Road Train Member
    1,698
    1,801
    Feb 21, 2010
    My 97 and 99 century both had det ser60. Had a problem breaking bolts on a pulley. Was common problem, Google it, bought a bracket for $100 or less on line. On my 97 around 850k. Did a Detroit stage 2 over haul. Detroit tried to talk me pit of it twice, because it wasnt yet needed. Around 1.3mil I had to replace a cam and 2 injectors. So I had them do all 6.
    I did PM every 12k and every oct for my birthday present to myself. I ran the rack.
  10. Still Glidin'
    6
    May 14, 2020
    Thanks. Any idea why the center section tends to burn out on a Detroit?
    blairandgretchen Thanks this.
  11. blairandgretchen
    13,926
    76,511
    Dec 9, 2011
    South west Missouri
    It’s a 3 piece slip joint unit.
