Pre-trip/Post trip Inspections
Discussion in 'Experienced Truckers' Advice' started by Wild Murphy, Sep 6, 2014.
  1. Wild Murphy
    Wild Murphy HAPPY TRUCK DRIVER
    942
    779
    I have been driving for a month now. I know in school we pretripped every time we came near the truck and were told to look over our truck every time we stopped for a quick look over, then at the end of the day to do a post trip. As a newbie, I usually check everything twice because I don't want to miss or forget something. Now maybe I am not seeing things right but it appears that at every truckstop I'm in it looks as if the only time someone looks at their truck to do any kind of pretrip is maybe at the fuel isle. I do believe it is important to do a pretrip. My question for the experienced truckers is what do you look for in your pre/post trip and what is your routine? Thanks!
  3. blairandgretchen
    13,929
    76,538
    Dec 9, 2011
    South west Missouri
    Oil, coolant, obvious leaks or loose stuff.
    Lights, tires, lugnuts, hub oil levels.
    Brake chambers, hoses, lines, leads.
    Permits, fire extinguisher, triangles.
    Mudflsps, stuff stuck in between tires.
    Just a real good looky look.
    5th wheel handles not pulled - in case I have been mouthy on the radio that day - I know - hard to believe, right?!
  4. Mev
    Mev Road Train Member
    3,109
    1,102
    Jul 29, 2009
    Walk the whole truck , look for damage , flats , do a complete light check etc.
    Look underneath for anything out of order
    Make sure logs are in perfect order before rolling out,etc.
    Where i work if something goes awry out on the road and they suspect a pretrip
    could have prevented it , they will hit the driver with 'points' .
    Enough points and your unemployed.
    pattyj, Wild Murphy and NavigatorWife Thank this.
  5. ladr
    ladr Road Train Member
    1,383
    15,431
    Apr 14, 2013
    GA
    Don't worry about the others.....you continue to do proper pretrips. How long does it take to open the hood, turn on the lights and check the truck and trailer out?
  6. Wild Murphy
    942
    779
    10 minutes is about what it takes for me. Haven't found anything major yet, but have found some trailer issues and had them fixed. I always feel better knowing I checked. I just never see anyone walk around the truck.
  7. mtoo
    mtoo Road Train Member
    1,940
    4,522
    Jan 15, 2011
    Retired on bended knee
    Keep looking at your truck/trl. Don't fall into that hole of just driving and never walking around your truck.
    A very large portion of the rubber on the road, is from drivers driving hundreds of miles or days with a flat. Eventually that good tire is going to get hot and give out.
    The percentage of drivers that get fuel or come out of the truck stop and never walk around the truck is amazing.
    NavigatorWife and Wild Murphy Thank this.
  8. Lepton1
    Lepton1 Road Train Member
    12,647
    25,589
    Nov 23, 2012
    Yukon, OK
    Get yourself a good air pressure gauge, the kind with a dial. Check the air pressure on every tire on pre trip, your 30 minute break, and post trip. Keep tabs on how the tires increase in pressure after rolling a while. Once you get the hang of it it only takes a couple more minutes to KNOW what your tire pressures are instead of simply thumping the tires and GUESSING.
    Whenever you hook up to a new trailer always check air pressure. It's surprising how often I'll hook to a trailer with tires as low as 60 lbs psi. Learn how to to use a 40' air line to add air to low tires.
    As you drive take note of all the scraps of blown truck tires scattered all over the freeways and highways. Those are generally cleaned up every day. I call those scraps "Tire Thumper Debris".
  9. kemosabi49
    10,977
    47,914
    Jan 13, 2013
    SW Arkansas
    mtoo is right. Don't pay any attention to the others. You are responible for making sure your truck is legal and safe. It's a lot easier to take care of a problem before you leave a safe place than to have to deal with it on the side of the road
  10. Voyager1968
    Voyager1968 Road Train Member
    2,378
    2,904
    Sep 11, 2008
    While there is no substitute for a tire gauge, if you've been in this profession for any number of years, and you are astute enough, you can tell, by thumping, the sound of a fully inflated tire versus one that has 60psi. I know I can. What I laugh at is the guys who just kick (most of the time wearing sneakers) the tires instead of even thumping them. In that case, you cannot tell if a tire is underinflated.
  11. mtoo
    1,940
    4,522
    Jan 15, 2011
    I thump my tires with a 3 pound sledge with a 10 inch handle. like Voyager1968 said you can tell the diff. It's the same hammer I use to "thump" a frozen brake drum
