Radios
Discussion in 'Questions From New Drivers' started by dave01282000, Jul 20, 2021.
  1. dave01282000
    dave01282000 Medium Load Member
    381
    803
    Jun 16, 2021
    Overall a lot of online reading tells me that two-way CB radios are still a valuable tool out on the road for situational awareness on wrecks, weather conditions, speed traps etc.
    Basic question...do company trucks often have a radio built in, or is it something you bring along and plug in to the cigarette lighter? I'm going on the assumption that companies would look on it as an extra frill and therefore wouldn't be inclined to have radios pre-installed in their fleet trucks.
    Thanks
    Dave
    Lucky12 and truckdriver31 Thank this.
  3. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    your own extra idea. you buy your own radio
    Lucky12 and dave01282000 Thank this.
  4. Dockbumper
    Dockbumper Road Train Member
    3,778
    9,863
    Apr 29, 2020
    Interestingly enough, Danny Herman equips all of their Company Trucks with a nice Cobra CB. I don't think it is very common in the industry at all. I was all set to install mine when I came to work for them. It is still in my side box.
  5. Frank Speak
    Frank Speak Road Train Member
    4,583
    14,117
    May 3, 2016
    Depending on the kind of trucking you do, they’re almost a necessity. I communicate with most of the scale houses at our customers via CB. Our trucks come with CBs, but, as the others stated, they’re on your dime at most places.
    That said, that $120.00 Cobra 29 classic will pay for itself 10 times over with the lost time you’ll avoid by getting a heads up about wrecks, construction and other crap that you can detour with enough warning.
    JReding, Lucky12, slow.rider and 5 others Thank this.
  6. Rideandrepair
    17,532
    56,814
    Aug 8, 2015
    X2 on the Cobra 29 Classic. Add a Astatic or Road King Noise cancelling mike for clarity, and a small speaker for clear reception. All are often on sale at Loves. Trucks are usually pre wired. Might need to buy an in line fuse for the CB. Easy enough to figure out, just a power plug, and an antenna, speaker plugs in back also. If you need an antenna. Francis, or Fire stick are pretty cheap, and work great. Usually a 4’ works best. Pretty standard set up, all I’ve ever used.
  7. dave01282000
    381
    803
    Jun 16, 2021
    Thanks, appreciate the recommendations.
    Would you recommend taking the radio in my car just to listen and try to figure out what's going on? I have zero experience with CB and wasn't sure if that would be helpful before I even step foot inside a tractor.
    Lucky12 and Rideandrepair Thank this.
  8. Dennixx
    Dennixx Road Train Member
    4,539
    14,592
    Feb 13, 2010
    twin cities
    Negative on the car..
    You will have enough of it in the truck..no training needed
  9. Rideandrepair
    17,532
    56,814
    Aug 8, 2015
    I used to hook mine up for traffic reports on vacations, came in handy when 1-40 slid off the side of the mountain, while in the Smokies. Lol. Took a crazy backroad through the Smokies in the Jeep. Best part of the whole vacation. Lol. You’ll need a plug for cigarette lighter, and an antenna. Wilson Lol’ Wil magnetic rooftop works real good. Kind of expensive, maybe $70 or more now? Nice to have anyway for future use on vacations, or long trips to a Terminal/ home, if wanted.
  10. Kyle G.
    Kyle G. Road Train Member
    3,901
    20,575
    Jan 23, 2016
    Eastern Iowa
    If your company doesn't supply a CB, your truck will most likely still be pre-wired for one, so it's just a matter of hooking up the wires. Super easy. Some guys go all out on their radios, but I just have a cheapo cobra with factory antennas. Suits me fine as I'm not a big talker.
    Lucky12, Speed_Drums and dave01282000 Thank this.
  11. SoulScream84
    3,447
    26,464
    Mar 21, 2020
    I'm old school, but can't even tell you the last time I had my CB hooked up. Part of that has to do with the horrible setup in Cascadias for antennas (2019 so I can't even find a mount that works), and they had the moronic idea of an internal antenna. The 2nd part of it is that despite all of the "it saved me" stories, I've received more bad information, and bs than if I'd sat at the counter of the Country Pride listening to super truckers.
    It was, and for some still is, a good tool. Most of the time though it's as useful as a hacksaw to fix a tire.
