Shifting techniques
Discussion in 'Questions From New Drivers' started by Ddr1992 579, Jul 4, 2021.
  1. Ddr1992 579
    Ddr1992 579 Medium Load Member
    395
    100
    Sep 10, 2018
    Can you shift a medium duty box truck (20,000gvwr to 33,000gvwr) with only using the clutch for shifting from neutral to first and for stopping/braking? I've never driven a box truck so idk and that's the reason I ask this question, and any truthful answers are appreciated, thank you
  3. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    Box trucks typically have a Eaton synchro six. They are synchronized so technically you are supposed to shift it like a car with one push of the clutch. Those transmissions are junk and the synchros are usually wore out so people float them anyhow. So to answer your question, yes you can shift without the clutch. It’s probably wore out anyhow
  4. 201
    201 Road Train Member
    12,732
    26,183
    Apr 16, 2014
    high plains colorado
    Can't find em', grind em',,,to shift a synchro trans like straight gears does more harm than good. Just shift it like a car, let them worry about the clutch.
  5. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    They're "not bad" to drive. Like the other fellow said, more than likely slightly " out of adjustment and hashed out.I drove one a few times 25,999gvw. I preferred to float by R P M and sound.
    Don379 Thanks this.
  6. Rideandrepair
    17,528
    56,787
    Aug 8, 2015
    I use to do it all day long in city traffic. Never tore one up.
  7. Frank Speak
    Frank Speak Road Train Member
    4,583
    14,117
    May 3, 2016
    Anything you get in now days will likely be an automatic.
    BUMBACLADWAR Thanks this.
  8. BUMBACLADWAR
    1,899
    1,923
    Dec 5, 2013
    My cousin drives a dump truck in Kansas City. They have around 80 trucks and they're all automatics
    Frank Speak Thanks this.
