Sleeper ac and apu.
Discussion in 'Questions From New Drivers' started by Yevgeniys95, May 29, 2018.
  1. Yevgeniys95
    Yevgeniys95 Bobtail Member
    8
    Dec 3, 2017
    So, i bought a 2013 kenworth t660
    The previous owner put a Tripac unit on it, but it does not work. Eitherway if it did, i would not use it because i team drive and it wouldnt work. Anyways, question is does the tripac unit cut off my standard AC to the sleeper? We have a studio sleeper, and the truck is running 24/7 on our trips, the ac back here does not work but the fans do (standard fans not tripac fans).
    So, is that caused by the tripac being installed?
  3. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Unless some gomer installed the APU and did a lot of crap he shouldn't have done, the APU HVAC system (including duct work) is supposed to be completely independent of the truck's sleeper HVAC system. Or at least every one I've dealt with was.
    KB3MMX and Bean Jr. Thank this.
  4. Yevgeniys95
    8
    Dec 3, 2017
    Okay thank you, now i know what to focus on fixing. Also, do you know if its possible to have my APU run while the truck is on idle? So it can work as my partner is driving?
  5. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    Jenya the tripac can be setup to work when truck is idling, when no idling, when your(driver) are not nearby...
  6. Farmerbob1
    Farmerbob1 Road Train Member
    3,685
    5,792
    Jan 17, 2017
    Why? The APU does nothing that the truck motor itself can't do, except turn on and off based on a thermostat.
    Once the temperature gets to where you want it, adjust the vent temperature and go to sleep.
    The APU is a fuel saving device. Running it when the engine is running just wastes fuel.
    Bean Jr. and DTP Thank this.
  7. STexan
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Do you know if the APU has a "shore power" outlet in the Sleeper? If so, then it might make sense to allow it to run while driving so co driver can run a microwave or what not. Otherwise running the APU while driving does not make much sense typically, as long as there is a good working inverter in the truck to power incidental things for the co driver
  8. driverdriver
    driverdriver Road Train Member
    4,254
    5,284
    May 30, 2011
    You would need a pretty long exstenion cord to use shore power while the truck was rolling down the road. Lol
    Baty Dispatch and Bean Jr. Thank this.
  9. driverdriver
    4,254
    5,284
    May 30, 2011
    There is only one reason to have your apu running while the truck is.
    And it's if your alternator has stopped working , it can help you make it to a repair shop by keeping your batteries alive.
    And yes it can be programed to run like that.
    Apu' s are for climate control and keeping batteries charged.
    When the truck is running co/driver can do 'whatever' using the inverter.
    As far as the sleeper a.c. not working , well that could be a number of things you'll need to take it to a trust worthy shop.
  10. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
    LOL! You have bigger problems than your APU. Just saying.
    driverdriver Thanks this.
  11. Ridgeline
    22,723
    123,052
    If you bought a truck, then you can afford to get it fixed right by a shop,
