Smartphone or Tablet
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by Bos111, May 24, 2021.
  1. Bos111
    Bos111 Bobtail Member
    12
    6
    May 29, 2020
    Hi guys, which device do you prefer ?
    Can i use only iPhone for logbook ?
  3. shooter19802003
    5,654
    42,113
    Feb 8, 2010
    Keep trucking has a free app for pre eld..
  4. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    If its the interface for your eld thats hooked to the truck ecm, an iphone will work fine (i assume, i use android)
    If younare running it as a paper logbook replacement, bear in mind you must be capable of printing it
    (Email to self and have printer)
  5. Brandt
    Brandt Road Train Member
    4,622
    6,355
    Sep 17, 2012
    If the ELD is app then you can probably use IPhone or tablet or both. My company use KeepTrukin. It's an app that that run on the tablet they give us. I could use my phone if I want to use it and connect to KeepTrukin brain that it hooked to the truck ECM and engine. Part of the setup it plugged into the truck main computer and it can read the engine and has GPS. So the app just connects to KeepTrukin system in the truck.
    Unless a truck has 1999 or older engine you can't run paper log or just app. You have to run the setup that hooks into ECM and has GPS.
  6. Frank Speak
    Frank Speak Road Train Member
    4,583
    14,117
    May 3, 2016
    We use KeepTruckin where I work too. I have the app on my IPhone and it connects via blue tooth when I get in my truck every morning. It's also connected to a dash cam (outward facing).
    Brandt Thanks this.
  7. 25(2)+2
    18,759
    45,960
    Sep 18, 2006
    the road less travelled
    The dash cam on what I drive is low light really wide angle. I've only checked it out once.
    The smartphone is a bit small to see. We were supposed to get a tablet, but I haven't talked to anyone using one, and my Acer Spin 3 is not practical.
    Frank Speak Thanks this.
