Speedometer not working problem
Discussion in 'Ask An Owner Operator' started by missjhawk, Jan 16, 2019.
  1. missjhawk
    missjhawk Medium Load Member
    571
    324
    Jul 24, 2013
    nutbush
    I have been in dealer for same thing 3 times within a month
    1st time they say speed sensor is out replaced it
    Week later same thing go back to dealer rhey check wires they found bent prong
    4 days later go back this time check light is on they say I had a code of speed sensor tampered with and bad sensor they cleared codes replaced sensor again
    Now 3days later same problem speedometer still not working right I am steady going to dealer for same thing no check light right now but what are they missing I been in 3 different dealer I'm still not fixed I'm tired of not being able to use my cruise then I loose a day of work they say the dealer is best but I can't tell it got to be something simple new sensor and wires are fine going to sensor what's left
  3. Ridgeline
    22,682
    121,621
    Did they offer you a ride along with their laptop to see if it is possibly the actual speedometer?
    I had a few go bad and the dealers were chasing their tails replacing everything except the actual speedometer. Once they got into the truck and saw that everything worked up to the speedometer, it was fixed.
  4. missjhawk
    571
    324
    Jul 24, 2013
    nutbush
    I called told them it's still not working just now they say i probably need to replace wiring harness but I'm going to go and buy the speedometer I have a pete where do I but it
  5. mitmaks
    mitmaks Road Train Member
    2,580
    2,093
    May 16, 2014
    So did they or didn't they replace wiring harness? Have them do layover on harness. I bet it will fix your problem
  6. missjhawk
    571
    324
    Jul 24, 2013
    nutbush
    They didn't they just said I had a prong bent they fixed it but now they're saying it's in my wiring harness or my yoke something bout 900 and a magnet but my speedometer was messing up b4 I put my clutch in December
  7. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    GPS Speedometer to the rescue..
