Spread axle and tridem...
Discussion in 'Flatbed Trucking Forum' started by RollinThunderVet, Dec 16, 2018.
  1. RollinThunderVet
    RollinThunderVet Heavy Load Member
    717
    970
    Looking to pick up a step deck.
    Curious on the axle setup.
    Someone please explain why and where you would want a 10ft spread. Obviously if in Florida you have to bring the rear axle up to be inside 41ft king pen to axle.
    What about triaxle? What's the deal in most states?
  3. supersnackbar
    20,079
    52,456
    Aug 19, 2007
    Your Town, USA
    Only worry about FL if it's a 53'. I pull 10' spreads on 48' step and flatbed there without issue. We haul glass of various sizes, but with spreads, I never scale anything under 45,000 and I am always legal. Plus, spreads ride better.
  4. RollinThunderVet
    717
    970
    It will be a 53 step.. curious what the max on a triple would be.
  5. snowwy
    snowwy Road Train Member
    20,611
    13,326
    Jul 6, 2009
    Fed bridge is 43,500 for a tri.
    A 10.4 2 axle spread is good for 40. 9.3 spread is good for 39. 8.2 spread is 38. Anything less is standard 34.
    YOu guys on the eastern side seem to have the ability to weight super loads on standard axles though.
    Some guys will say the western side can also. But I keep getting told NO. Need the axles. We were permitted for 60. Then it was 50. Regardless of what permit says, 43,500 is max.
  6. RollinThunderVet
    717
    970
    That's so stupid if you have 40k 10ft apart, and you add 4 extra tires to distribute the weight but only increase 3500 lbs.
    A 10ft spread @ 40k would equal around 5k lbs of pressure per tire. With a triple even at 48k that pressure would only be 4k lbs.
    Who writes these idiotic laws?
  7. snowwy
    20,611
    13,326
    Jul 6, 2009
    I've been thinking that same thing. ^^^
    1 extra axle only gains 3,500 pounds. But what's the weight of that axle being added. So in reality you're only gaining an additional 2,500 pounds of payload. Whatever the math comes to after the weight of the axle.
    A second axle bumps you up to 52,500 on the 4 axles. You gain an extra 9,000 pounds.
    But here's an even more idiotic thing.
    The recent dump truck discussion. For a standard dump truck. 10 wheels. Is good for roughly 12 tons. Make it a Tri and you can add an extra 3 tons. 6,000 pounds extra. Make it a quad. That's another 2 tons. 4,000 pounds.
    12, 15, and 17 tons.
    That's roughly speaking. Depending on the weight of the truck.
    The rules for a axle set are different on a dump truck then a 53 ft trailer. 2 sets of bridge laws.
    Apparently on the eastern side. There's a 3rd bridge law. Which allows for much heavier loads.
    Dump trucks on the east can haul super loads where as on the west. No can do without the extra axles.
