Steering recall interim fix
Discussion in 'Volvo Forum' started by zmpart, Mar 25, 2016.
  1. zmpart
    zmpart Light Load Member
    135
    92
    Nov 27, 2010
    Can anyone post a photo showing the interim fix on the 2016 Volvo steering shaft recall so I can compare what was done to mine? Thanks
  3. MOGLAR
    MOGLAR Heavy Load Member
    743
    518
    Jun 19, 2013
    Kansas City , MO
    There is NO INTERIM FIX!!! You need to go to a Volvo dealer ASAP!! It must be reviewed (and repaired if necessary) by Volvo. Backyard mechanic high jinx wont work. Volvo will pay for the tow. Better call a Volvo dealer and get inspected ASAP!
    By the way...if you are currently driving a recalled Volvo and get caught at the scales. You will be put out of service, ticketed and fined. Yes you will have CSA points assessed against you. The DOT is dead serious about this. The problem is that significant.
    PS You will need to have documentation of the inspection/repair from Volvo to show the DOT if you get pulled in. I repeat....MAKE SURE YOU HAVE DOCUMENTATION SHOWING YOU HAD YOUR TRUCK INSPECTED OR REPAIRED!! IF NOT YOU WILL SUFFER THE CONSEQUENCES:protest::protest::protest::protest::protest::protest::protest::protest::protest:.
  4. Irishfan83
    Irishfan83 Bobtail Member
    9
    Mar 19, 2016
    The temp fix is just to add another tool pin should be about half way down on the block, but after it's been and has passed inspection.
  5. Irishfan83
    9
    Mar 19, 2016
    Roll pin darn auto correct
  6. zmpart
    135
    92
    Nov 27, 2010
    Thanks Irish. That is what was done. Just wanted to make sure.
    Moglar there definitely is an interim fix check online. The permanent solution is still being manufactured.
  7. MOGLAR
    743
    518
    Jun 19, 2013
    Kansas City , MO
    I know there is an interim fix. What I am saying is that drivers should not do this themselves (unless you are a certified mechanic that can sign off on truck repairs).
    DOT is throwing trucks out of service left and right. I am saying make sure you have documentation of the inspection/repair to avoid BS at the scale house or if you get pulled over. You will be put out of service unless you can demonstrate you complied with the recall. DOCUMENTATION IS THE COIN OF THE REALM :biggrin_25514::biggrin_25514::biggrin_25514::biggrin_25514::biggrin_25514::biggrin_25514::biggrin_25514::biggrin_25514:
    PS. Please do not listen to truck stop banter or trucking company shills when it comes to having some documentation verifying you complied with the recall. YOU HAVE TO HAVE IT!! :biggrin_25525:
  8. Irishfan83
    9
    Mar 19, 2016
    Correct the placement of the pin is very specific. So either dealer or repair shop has to do it
  9. flood
    flood Road Train Member
    4,168
    4,047
    Dec 25, 2010
    dot has photos of what the temp fix looks like so you don't need documentation verifying it was done
    KB3MMX Thanks this.
  10. VolvoTerry
    VolvoTerry Light Load Member
    293
    377
    Sep 7, 2015
    Based out of Omaha,NE
    I would have to strongly agree with Moglar on the need to take the truck to a shop. The "interim" fix is a simple drilling and pin set. However, before that is done, a gauge is put to the Clamp(faulty piece), and if it exceeds the specs there is a real possibility of failure even with the interim fix. So a new steering rod clamp would have to put on, with the fix done at that time.
  11. MOGLAR
    743
    518
    Jun 19, 2013
    Kansas City , MO
    The DOT will want to see proof you adressed the recall. It's not hard to get. They are putting affected Volvos out Of service and issueing tickets.
