Switching Tri-Pac APU to closed loop
Discussion in 'Ask An Owner Operator' started by 86scotty, May 7, 2022.
  1. 86scotty
    86scotty Road Train Member
    4,699
    12,896
    Aug 27, 2017
    Appalachia
    Twice lately my Tri Pac has decided to dump all my coolant on a hill. First was water pump shaft seal failure, second time not yet known, unless I got a new bad water pump. It is a TK factory part, not cheap aftermarket. Weird thing is I can't get it to leak again.
    All this leads me to wonder why I even keep it plumbed to the truck. I don't run up north or anywhere really cold. I don't need the pre-heating function. I've already bought the controller to separate my Espar from the Tri pac system, just haven't done it yet. I just wonder why these systems are all integrated and with Tri-pac one error code and everything shuts down. One small coolant leak and you might burn up your $25k truck engine.
    This can be done and I'm gonna research the cost. It's less complex than I realized, I basically need an expansion tank and for some reason the CLC manifold. I'm not 100% sure why this part is necessary.
    Anyone ever do this?
    https://www.thermoking.com/content/...ts/TriPac Closed Loop Cooling 55827-19-IM.pdf
    D.Tibbitt, Siinman, xsetra and 2 others Thank this.
  3. simonsocm
    simonsocm Light Load Member
    111
    67
    Aug 17, 2019
    I'd imagine all you'd need is a radiator, fan and a pressure cap on the radiator. Not much else as long as the engine has a thermostat.
  4. 86scotty
    4,699
    12,896
    Aug 27, 2017
    Appalachia
    Yep, look at the link above. The Tripac already has a small radiator, called a pre-cooler, behind the fan in the diagram (inside the case). I didn't think it would be big enough the APU dedicated but you can according to that diagram, just add expansion tank.
    I'm hoping to hear from someone that has done it.
    mtoo and Another Canadian driver Thank this.
  5. mtoo
    mtoo Road Train Member
    1,940
    4,522
    Jan 15, 2011
    Retired on bended knee
    The simpler the system is the better. I agree, if you don't run up north then get rid of potential leaks. I never converted mine, but I did think about it. Good luck
    86scotty Thanks this.
  6. Siinman
    Siinman Road Train Member
    5,513
    14,173
    Mar 5, 2017
    Kansas City, MO.
    This is the reason I went with the EPU on new truck from them. On another note there is a group on Facebook for thermoking APU that might be a good question for them.
    86scotty and blairandgretchen Thank this.
  7. blairandgretchen
    13,929
    76,532
    Dec 9, 2011
    South west Missouri
    The only thing I miss about FB was those niche groups.
    Need to create more on here I guess.
    86scotty, Siinman and LoneRanger Thank this.
  8. Siinman
    5,513
    14,173
    Mar 5, 2017
    Kansas City, MO.
    Yeah I like a couple of the groups on Facebook. But most of it just sucks the life out of you.
    blairandgretchen and flood Thank this.
  9. 86scotty
    4,699
    12,896
    Aug 27, 2017
    Appalachia
    I checked things out under my truck today and I'm not sure I can do this like the diagram I linked above. All of my APU wires go through the floor just about where the bracket, tank and manifold would go, and those need to be high like that to work correctly. Of course it's all hoses and I could mount the tank about anywhere. I can also fab the bracket. Currently thinking about using the other side of the APU case.
    This week I'll talk to some TK dealers and see how crazy their prices are on the parts, or if they are even available.
  10. D.Tibbitt
    156,930
    does your apu have the shutoff valves for the coolant, running from the APU to the main engine water pump?
    Siinman Thanks this.
  11. Dave_in_AZ
    423,519
    Ask Texas Truck AC in Dallas. They are very knowledgeable.
    As far as TK dealers go, ask the one in Tolleson or Gulfport.
