Tarp corner protectors
Discussion in 'Flatbed Trucking Forum' started by tony97905, Jan 5, 2016.
  1. tony97905
    tony97905 Road Train Member
    1,023
    12,241
    Feb 28, 2015
    Land of Ahhhhhs
    Newbie flatbedder here so go easy....how do you hold those corner protectors in place while tarping that look triangular on the bottom with a raised smooth knob on top? I don't see a strap holding them in any way so I'm confused. Thanks in advance for the lesson!
  3. pigeon river trucking
    pigeon river trucking Light Load Member
    132
    99
    Jan 1, 2016
    michigan
  4. frt60
    frt60 Medium Load Member
    312
    266
    May 22, 2014
    Duct tape or a smll srew or nail
    MJ1657 Thanks this.
  5. blairandgretchen
    13,929
    76,536
    Dec 9, 2011
    South west Missouri
    Jedi mind trick .
    No, Gorilla tape has worked ok for me.
    MJ1657 Thanks this.
  6. Long FLD
    Long FLD Road Train Member
    12,837
    53,718
    Mar 4, 2015
  7. barroll
    barroll Road Train Member
    1,096
    544
    Nov 23, 2010
    Southwest Michigan
    Gorilla tape, nails, staple gun, magnets, tarp straps, 2" straps, jamming them under the top sheet, c-clamps, steel banding; I've done it all. Do whatever works for that particular load.
  8. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,335
    Feb 21, 2015
    Bement, IL
    Everyone has given some great ideas. Just keep in mind, that some receivers will reject loads with tape residue, staple holes, nail holes, etc. as damaged. Just use some (not so)common sense and you'll be fine.
  9. Chewy352
    Chewy352 Road Train Member
    1,797
    11,620
    Dec 17, 2013
    Enid, OK
    Moving blankets stay in place nicely
    Al. Roper Thanks this.
  10. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Northern Tools sells 10x10 cargo blankets for $15. I keep 8 of them rolled up under my bunk for when ever the need.
    Hurst
  11. Chewy352
    1,797
    11,620
    Dec 17, 2013
    Enid, OK
    15 bucks is crazy. I got my 2 for free from a bedbugger. Starting to look for more. Should be able to buy them for just a few to 5 bucks off of them.
  12. barroll
    1,096
    544
    Nov 23, 2010
    Southwest Michigan
    Cintas rubber bottom foot traffic mats work a whole lot better. Good luck finding them, though. I've had the best luck with welding shops that have burned holes in them and had to pay the deposit to get clean ones.
    Pig mats with a chain ptotector riveted to the edge to keep them from sliding off the corner under a strap work pretty well, too. Just carry a drill to get the rivets out when needed.
