Tri-rail vs singles (chains)
Discussion in 'Questions From New Drivers' started by road_runner, Feb 16, 2013.
  1. road_runner
    road_runner Road Train Member
    3,570
    9,181
    Mar 26, 2012
    Montucky
    Is there really a noticeable difference between using tri-rail chains and singles when it comes to climbing steep snow covered grades? Also, I've been only chaining up my passenger side tire (got tired of dodging snow plows & other trucks) and I've been doing well going uphill with my differential lock on. Is this a good practice or am I just pushing my luck?
  3. okiedokie
    okiedokie Road Train Member
    13,723
    108,379
    Jun 13, 2011
    PNWET
    Yes you are lucky. A Single on drivers still has the other tire barefoot. You will spin out it's just a matter of time or should I say Snow. If your going to throw Iron......put the 3 railers on. Then if ya spin out well it was not because you did not have enough Iron on. If you are concerned about plows,ect. turn your truck at a angle and use your trailer as a shield.
    PE_T and road_runner Thank this.
  4. striker
    striker Road Train Member
    6,023
    6,439
    Aug 8, 2009
    Denver, Co
    what your doing is not legal out west for chain requirements. Minimum chains in Colorado is one on each outboard drive tire of your primary drive axle. Using one chain on one tire only can earn you a $500 ticket.
  5. Saddletramp1200
    Saddletramp1200 Road Train Member
    2,111
    2,836
    Sep 4, 2011
    Houston Texas,USA
    Hanging Iron. Chain two & one. Drives first, Left Front tire, then limp to a truck stop and park it. If it's that bad you need to park it. Wait on the Sand man. Never seen a dispatcher chain up an office chair.
    okiedokie Thanks this.
  6. CenutryClass
    CenutryClass Road Train Member
    1,539
    859
    Feb 15, 2006
    If you get paid to chain, just do it right..I've been at near gross on three railers on the drives, and still get stuck sometimes.
    At con-way, not running max chains at all times and you wreck or spin out = fired if you wreck or a writeup.
  7. road_runner
    3,570
    9,181
    Mar 26, 2012
    Montucky
    Thx. They do pay us to chain. So I will do it the right way from now on based on everyones advice. I used to have singles and tri-rails. They took my singles when my truck went in for maintenance at the company depot.
  8. road_runner
    3,570
    9,181
    Mar 26, 2012
    Montucky
    They will also can us if we wreck. Spun out twice, but they didnt care.
    Only reason why i am asking about the difference is cause I am about to go raid the supply closet and find me another set of singles.
