Trying to due some PM work
Discussion in 'Experienced Truckers' Advice' started by J.S., Jan 11, 2025.
  1. J.S.
    J.S. Medium Load Member
    482
    214
    Jun 27, 2015
    Texas
    The book isn’t descriptive enough. The pics it has are of a 2 plug system so the fill is obvious. Mine is the same axle but has three plugs and so it’s confusing. Which plug do y’all think is the fill? Pic attached
    JolliRoger and blairandgretchen Thank this.
  3. Diesel Dave
    9,630
    32,489
    Jan 20, 2010
    Hesperia, Ca.
    That rear one is for a temperature sensor. Use the one on the front on the side. It’s about in the center of the axle.
    JolliRoger and AModelCat Thank this.
  4. Ridgeline
    22,717
    123,131
    OK, I won't get into the owning the truck bit but here is what you need to know.
    The bottom plug is for draining the oil, the middle plug is for the temp sensor and the top one is for the fill.
    Opps, Dave posted before me.
  5. snowwy
    snowwy Road Train Member
    20,611
    13,326
    Jul 6, 2009
    Isn't the side where the sensor goes?
    You fill it up that high and you get a ton of oil when the axle is pulled.
    I've seen axles pulled and there usually isn't much oil that comes out.
    Where's the wiring for the sensor?
    And where's the sensor at?
  6. blairandgretchen
    13,926
    76,509
    Dec 9, 2011
    South west Missouri
    Yup - got me.
    Top - fill
    Middle- temp sensor
    Bottom - drain.
    Stick yer little finger in the top one and feel around like a teenager, and if it gets all wet and stinky - (because that stuff does stink),
    Then button her up and take her to work.
    JolliRoger, Rugerfan and Diesel Dave Thank this.
  7. blairandgretchen
    13,926
    76,509
    Dec 9, 2011
    South west Missouri
    Probably didn’t come spec with a sensor.
    Angle of photo is deceiving - should be at a level to bathe in oil.
    JolliRoger, snowwy and Diesel Dave Thank this.
  8. AModelCat
    164,498
    The sensor needs to be in the oil, so it would be installed in the middle hole.
    The upper hole is the fill/level hole. On a truck with air ride I've always filled the diffs with the suspension inflated. Most air ride suspensions will cause the diff to pitch forward when deflated, which would cause the fill hole to sit higher.
    Plus the diff and the wheel ends share oil, so you want the oil level in the diff to be high enough that oil can trickle its way down the axle tubes to the wheel bearings. The upper plug should set the level to roughly the bottom of the axle tube.
    beastr123, snowwy and blairandgretchen Thank this.
