TTR has far reaching affects...
Discussion in 'Questions From New Drivers' started by scottied67, Sep 7, 2022.
  1. scottied67
    scottied67 Road Train Member
    10,826
    12,675
    Mar 14, 2010
    california norte
    Some of you may remember a little innocuous post from some years back that spun viral right here on TTR. It was a question of which lane should truckers execute a right turn when encountering a double right turn situation. The thread responses reached epic proportion, garnering into the several thousands of responses and hundreds of pages. After the horse had been thoroughly beaten, the mods finally shut the thread down.
    But I believe that massive thread had far reaching affects. Since the debut of the thread, I have seen several states define which lane truckers should be in for double right turns; they no longer want to leave it up to the 'pro' trucker to decide because, as we saw on the thread if you ask 10,000 truckers a question you will end up with 15,000 answers. Ok so check the pics below for the definitive proper lane to be in for your double right turns and finally put this debate for rest for good! drt.jpg drt3.jpg
  3. Lyle H
    Lyle H Road Train Member
    1,292
    2,942
    Apr 16, 2014
    So they still trust truckers to know which lane to turn left in there?
    JReding and Kyle G. Thank this.
  4. Val_Caldera
    Val_Caldera Road Train Member
    2,569
    7,939
    Apr 2, 2021
    TARHEEL
    The sign stating "TRUCKS" is rather vague.
    ALL TRUCKS or BOX TRUCKS or EXCEPTIONS FOR OVERSIZE/OVERWIDE??
    Typical State Sign.
    Sometimes the Inside "Clearance" doesn't allow Clearance.
    'Tween 00:01 and 05:00 should be "Choose Your Best Lane Option".
    For Double Left Turn Lanes, whether a car or CMV, I wood B In The Right Left Lane, not the Left Left Lane.
    Geekonthestreet and JReding Thank this.
  5. tiddlytanker
    tiddlytanker Light Load Member
    252
    768
    May 4, 2017
    Minot, ND
    By default you would want to be in the left lane because otherwise you will be taking out curbs, signs, and stop lights. I guess they designed this intersection for trucks to be in the right lane.
    I really appreciate the signage and wish they would do it more. Sometimes I dont recognize its a double turn lane until its too late and then I have to rely on drivers being courteous and letting me change lanes.
  6. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    Your example only proves that's the appropriate lane for that particular turn. They're all different and most of us know it's usually the outside lane that's wide enough for us...but not always as your example shows.
  7. Lennythedriver
    Lennythedriver Road Train Member
    2,411
    8,223
    Feb 14, 2020
    A lot of times you don’t know that an intersection has double turn lanes until you get right up on it. They need to do a better job with signs further back so we can get in the outside lane. Right or left turns turning in the inside lane is a no no for me. This particular intersection shown is designed for trucks to turn in that lane. Most are not, you’d be swinging wide into the outer lane.
  8. Moose1958
    Moose1958 Road Train Member
    15,291
    33,959
    Dec 17, 2010
    Williesburg, Virignia
    Is that even a legal regulatory sign? I don't see a white background on the lower part.
  9. Terlingua
    Terlingua Medium Load Member
    487
    1,021
    Oct 24, 2021
    Schneider teaches students to use the right hand lane when two lanes turn right and keep going forward into the left lanes space when it's clear if needed to make the turn. They want you keep the traffic on your drivers side instead of the blind side. That or make a buttonhook and control both lanes.
  10. Cat sdp
    Cat sdp . .
    21,298
    76,141
    Apr 8, 2012
    Orion's Belt
    I’d block both lanes……. But some say I have an attitude problem
  11. scottied67
    10,826
    12,675
    Mar 14, 2010
    california norte
    Post #8 above explains why the right turn lane is the proper one.
    Rideandrepair Thanks this.
