Turn signals
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Andres Guerrero, Jun 11, 2022.
  1. Andres Guerrero
    Andres Guerrero Bobtail Member
    31
    14
    Sep 3, 2015
    Adding some turn signals to my mirrors having some trouble wiring them up. Should i tap into the wiring on the turn signal switch or pull power from the turn signals on my headlights? Or is there another way of doing this?
    blairandgretchen Thanks this.
  3. blairandgretchen
    13,929
    76,536
    Dec 9, 2011
    South west Missouri
  4. Andres Guerrero
    31
    14
    Sep 3, 2015
  5. Six9GS
    Six9GS Road Train Member
    1,473
    3,697
    Dec 3, 2012
    Yuma, AZ
    In general, I'd recommend tapping in at the front fender. Quite possible the turn signal switch in the cab feeds a relay and not the actual lights. This is done to allow the turn signal in the cab to be a smaller wire drawing alot less amperage. Anyway, lots of advantages to having the turn signal switch feeding a relay and not the actual lights, and, to the best of my knowledge, is the usual scheme.
    However, I only know from common knowledge and do not know for certain on the specific year and model you mentioned.
  6. RocketScott
    RocketScott Medium Load Member
    579
    949
    Apr 10, 2013
    Kentucky
    There's no *power* relay for the turn signals unless someone added it
    There should be a connector on either side with four wires, it's labeled 'mirror options' on the wiring diagram. I can't remember if it's in the door, pretty sure it's in the cab somewhere around where the wires would pass through to the door
    Left side will have 302,228,5, 239
    Right side will have 302, 227, 5, 239
    302 is for mirror heat
    227/228 are turn lights
    5 is for clearance lights
    239 is ground
  7. Last Call
    Last Call Road Train Member
    7,568
    45,912
    Mar 15, 2021
    Your should have alittleore clarification when you make a statement .. there is a turn signal flasher relay.. so technically there is a relay
    And if the lights he is installing on the mirrors are LED he's probably gonning to have to change that relay to get them to fire..
  8. RocketScott
    579
    949
    Apr 10, 2013
    Kentucky
    The post above mine wasn't talking about the flasher. They stated that there may be a power relay
    Regardless, I edited my post
    spsauerland and Last Call Thank this.
  9. Trucker61016
    Trucker61016 Road Train Member
    1,574
    4,547
    Sep 18, 2017
    Linville, Va
    No you need to add blinker fluid.....everyone seems to forget this step... :rolleyes:
    RocketScott Thanks this.
  10. Last Call
    7,568
    45,912
    Mar 15, 2021
    I'am following you now LOL.. my fault for misunderstanding you
