Walking the hoses
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by ronjeremyjr, Jul 4, 2020.
  1. ronjeremyjr
    ronjeremyjr Medium Load Member
    302
    392
    Mar 6, 2020
    NY Tristate Area
    When hauling fuel I’ve heard the term on here walking the hoses, what is that?.
  3. Anywhichwaybutloose
    Anywhichwaybutloose Light Load Member
    159
    265
    Jun 24, 2017
    You raise the hose starting at the tank and walk with the hose in the air to drain it.
    tommymonza, ronjeremyjr, alds and 4 others Thank this.
  4. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    The same as rolling the hose. It's just a way to drain your hoses after you've dropped. It takes all the weight of the gasoline or whatever you're dropping and as you roll the hose you can load it on the truck..
    tommymonza Thanks this.
  5. REO6205
    REO6205 Road Train Member
    13,168
    60,499
    Feb 15, 2014
    California.
    Don't forget about not dropping the end of the hose on the pavement. Set it down gently, maybe catch it with the toe of your boot.
    If you drop the end of the hose the fitting can get out of round and then it's difficult to use.
  6. Judge
    91,776
    Easy Way.
    tommymonza and ronjeremyjr Thank this.
  7. ronjeremyjr
    302
    392
    Mar 6, 2020
    NY Tristate Area
    Anybody ever use this product
  8. REO6205
    13,168
    60,499
    Feb 15, 2014
    California.
  9. tommymonza
    tommymonza Road Train Member
    4,519
    12,849
    Sep 10, 2013
    S.W. Florida
    I always hated disconnecting the hoses from the cows when I was hauling milk
    I could never remember righty tightey lefty Lucy
    Dam cows can get Cranky
    91B20H8 and kemosabi49 Thank this.
  10. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    When I did fuel I used the roll method. Unhook from the truck/trailer, plug the truck/trailer, cap the hose then in about a 4-5’ circle roll the hose towards the tank, with the tank end being at the bottom of the roll, let it drain a second, then let the hose roll lay down, unhook and plug the hose, walk back pickup the other end stuff her in the hose tube, then unhook plug the vapor, stuff it in the tube, walk it just to be safe, unhook n plug it then stuff her in the tube. I always stuff the hose tubes with the truck/trailer end first that way when to pull them out they come out customer end first. Biggest thing to do is get a routine down and make it habit as in like you can do it with your eyes closed type of habit.
    91B20H8, intrepidor and ronjeremyjr Thank this.
  11. mustang190
    mustang190 Road Train Member
    2,885
    6,227
    Jan 18, 2011
    Florida Panhandle
    Normally the pumps at the airports and the pump on the trailer pulls all of the jet fuel out of the hoses.
