Weird question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by joey7119, Mar 12, 2023.
  1. joey7119
    joey7119 Light Load Member
    85
    37
    May 30, 2008
    baltimore, maryland
    i have a 2014 kenworth t660. Do i have to set the parking brakes when i connect to a trailer in order for the airbags to fill? every time i back under a trailer connect and raise the landing gear the tractor airbags deflate and take a very long time to inflate if at all. Am i doing something wrong? Any help is appreciated..thanks
  3. tscottme
    tscottme Road Train Member
    I would back under the trailer, do tug test. Park, connect electrical cable, push in the red brake valve, do walk around inspection, return to landing gear handle and raise the legs. Trailer air bags deflate, which effectively raise the trailer nose, and once the trailer air bags are inflated, and if tractor air bags are inflated, it will make raising landing gear easier. However, 99.99% of OTR drivers drop trailer tooo dang high and then blame the switcher when the next driver has a hard time.
    Bean Jr. and joey7119 Thank this.
  4. bad-luck
    bad-luck Road Train Member
    3,422
    6,301
    Nov 16, 2013
    Baltimore, Maryland
    The tractor air bags don't deflate, what is happening is they went down because you put more weight on the tractor and they are re-leveling. Also is always best to set your parking break any time you get out of the truck, make a habit of it.
  5. Judge
    91,553
    If bags deflate and don’t want to raise back up due to weight, you may have an air leak either bad bag or leveling valve.
    Truck bags shouldn’t deflate by setting brakes, trailers can be set that way.
