What am I missing here?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Spartanmetal, Feb 2, 2020.
  1. Spartanmetal
    Spartanmetal Bobtail Member
    14
    37
    Nov 23, 2019
    I have a question re: ultrashift plus transmissions
    I drive a 2020 kenworth t680 with a Cummins x15
    And a 13 speed ultrashift transmission.
    How do I engage the engine brake in 8 gear or less. The jake works great on the highway but if I want to crawl down a steep hill I can’t figure out how to engage the jake. A work around is to speed up to 10th and then the jake works fine and I can control my speed from there.
    Has anyone else experienced this or is it just me .
    I am thinking that there has to be some parameters that the shop guys can change with their computer
    Ken
  3. blairandgretchen
    13,870
    76,047
    Dec 9, 2011
    South west Missouri
    Probably parameters.
    Personally, with a 13 manual, I’m off the jakes below 8th gear - 3:55 rears.
    062 Thanks this.
  4. 062
    062 Road Train Member
    6,317
    33,950
    Oct 20, 2013
    You probably have mufflers on your truck too.... smh how you going to Jake through the parking lot at 3am?
    To the op most likely parameters. I have mine set to work above 10mph.
    Bean Jr. and blairandgretchen Thank this.
  5. Ffx95
    Ffx95 Road Train Member
    1,370
    2,635
    May 18, 2017
    I have a t680 but with a Paccar and the Endurant. The jakes cut off at around 15mph but it will work regardless of gear or speed if I set it in manual mode. Give that a try?
    062 Thanks this.
  6. blairandgretchen
    13,870
    76,047
    Dec 9, 2011
    South west Missouri
    3am?
    I’m still in bed dreaming the boss will give me a shiny new Cascadia.
    Bean Jr., Milr72 and 062 Thank this.
  7. haycarter
    haycarter Road Train Member
    1,920
    5,317
    Jun 9, 2012
    Australia
    ^^^^^^^^^What he said^^^^^^^^^^^^^^
  8. Spartanmetal
    14
    37
    Nov 23, 2019
    I did try that,
    I am going to get the shop to try and change some parameters.
    I am just new to this ultrashift stuff.
    haycarter Thanks this.
  9. Spartanmetal
    14
    37
    Nov 23, 2019
    If anyone is interested in the solution to my Jake brake issues, it was a setting in the parameters. The Jake was set to turn of at speeds under 35 mph. Up here in British Columbia , Canada, that just won't work. We set the cut off speed down to 15 mph. I haven't tried it yet, but that should work a lot better.
    Drive safe,
    Ken
