What causes black smoke while accelerating?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 77fib77, Mar 28, 2016.
  1. 77fib77
    77fib77 Road Train Member
    11,526
    75,673
    Jul 7, 2010
    St Louis
    Is it a bad injector? Or a turbo? Bad CAC?
  3. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    What engine u got? Pre emissions? It could be just soot...
    77fib77 Thanks this.
  4. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Let's see,,
    Many things come into play.
    -Could be a bad turbo or turbo actuator.
    -Could be a bad egr valve not closing.
    -Could be a serious boost leak in the charge air system .
    - If the engine is mechanically injected it could be bad something in the injection pump not set up correctly.
    - Bad injector or injectors.
    - plugged air filters.
    You get my point, that's just the short list. .........
    Start off with what kind of truck , year , engine and maybe some one can narrow it down for you.
  5. Luwi67
    Luwi67 Heavy Load Member
    750
    484
    Oct 24, 2012
    Long island
    Incomplete combustion.
  6. CasanovaCruiser
    CasanovaCruiser Road Train Member
    1,712
    2,669
    Jun 2, 2015
    Indiana
    Fuel to air ratio is off during combustion.
    There's a balance to be maintained for peak efficiency. The injectors spray fuel and the turbo pushes air in relation to one another to maintain this efficiency.
    When you get black smoke your injectors are spraying more fuel and you're not getting enough air (oxygen) to burn it all completely.
    In other words you're running rich.
  7. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    Start off with the easiest thing first guys. When was the air cleaners last changed.
    baha Thanks this.
  8. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    If it's a mechanical engine, could just be the driver putting his foot down too hard for the load and conditions.
  9. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    if mixture is a bit reach - it is not so bad as lean mixture.
    If u can see some smoke - keep it on road, but if smoke is really dark and it is a lot of black clouds - mixture is too reach
  10. 77fib77
    11,526
    75,673
    Jul 7, 2010
    St Louis
    It's an isx 870 04 9200i. Egr is blocked off. The turbo doesn't get above 20 si, most of the time around 14psi. If I'm light on throttle no smoke.
  11. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    sounds like boost leak to me
    CasanovaCruiser and 77fib77 Thank this.
