What is this button for?
Discussion in 'Ask An Owner Operator' started by Keepforgettingmypassword, May 1, 2024.
  1. Keepforgettingmypassword
    Keepforgettingmypassword Heavy Load Member
    738
    938
    Jan 11, 2022
  3. Concorde
    Concorde Road Train Member
    5,423
    19,080
    Jun 29, 2016
    West Melbourne Florida
    For night driving mode :)
    Keepforgettingmypassword and Numb Thank this.
  4. Dave1837
    Dave1837 Road Train Member
    1,402
    4,349
    Nov 16, 2019
    Pennsylvania
    Top is power divider, bottom is a neutral switch. Dad had one in his Mack years ago and I'm pretty sure he used it when he was connected to a conveyer that was milling the road that pulled/pushed the truck
  5. Keepforgettingmypassword
    738
    938
    Jan 11, 2022
    I wouldn't need to use it unless using a attachment. Thanks.
  6. 86scotty
    86scotty Road Train Member
    4,676
    12,828
    Aug 27, 2017
    Appalachia
    That's two buttons.
  7. Espressolane
    18,573
    116,208
    The top button is for when you can’t get a four wheel burn out, so you press that button and it will lock the axles, then roll through the bleach water and gas it hard. That will heat up and clean the tires for maximum traction.
    The second button is for the nitrous gas control. You should only use that when you’re getting ready to launch, maybe a shot for a burn out. Thats not something you want to have turned on when just rolling around. You gotta have lots of throttle when you use that. Could blow a motor like that.
  8. LTLTRUCKDRIVER
    LTLTRUCKDRIVER Light Load Member
    181
    336
    Jun 3, 2019
    The last Mack I drove was 1984 R-Model..... " No Nitro Button".
  9. abyliks
    abyliks Road Train Member
    4,078
    9,590
    May 2, 2010
    ludlow MA
    if I had to guess Neutral switch, turn it on with pto place trans in 4th gear and put her up, I haven’t been stuck inside that new of a pile of #### though
  10. Keepforgettingmypassword
    738
    938
    Jan 11, 2022
    Thank you ever one. I think I get it now. I running dump truck for a paving company. So far I have 12 days experience and comply miss the Eaton manual transmission mission. This mack is driving me wack.
    The hands down best windshield wiper speed controll knob ever thou. Including any 4 wheel I've ever driven. This one turns to adjust speed. Vs having pre selected speeds.
