What's It For?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ProfessionalNoticer, Jun 3, 2021.
  1. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    Anyone know why this hose is here and if can be deleted from the system? I'm referring to the blue 1.5" coolant hose from the bottom of the expansion tank to the back of the water pump housing on a 3406e CAT.
  3. Luwi67
    Luwi67 Heavy Load Member
    750
    485
    Oct 24, 2012
    Long island
    I think it's called a shunt line. Probably a bad idea to delete it.
  4. supersnackbar
    20,074
    52,409
    Aug 19, 2007
    Your Town, USA
    If the manufacturer put it on, it's there for a reason. I'd leave it like they built it.
    buddyd157 and Roger McG Thank this.
  5. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    Finding that fitting seems impossible. KW doesn't carry it. CAT doesn't carry it. None of the hydraulic fitting companies in my area carry it. And all the junk yards near me won't pull one off an engine in their yards. This is unreal.
  6. ClineER
    ClineER Light Load Member
    229
    139
    Apr 27, 2016
    N.E. Oklahoma
    That's the line that fills the engine with coolant, it should be a standard 1in water line. The fittings should be, 1in or 3/4in pipe thread by 1in barb. May have to pick up a 45 elbow from plumbing store.
  7. Rideandrepair
    17,541
    56,833
    Aug 8, 2015
    That’s all it is, tapered pipe thread nipple. usually brass, found at hardware store.
    lester Thanks this.
  8. RocketScott
    RocketScott Medium Load Member
    579
    949
    Apr 10, 2013
    Kentucky
    Which fitting?
    Hose barbs are everywhere
    lester Thanks this.
  9. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    The fitting is 3/4" pipe thread to 1.5" hose barb on a 45 degree and I cannot find it anywhere.
  10. God prefers Diesels
    4,198
    22,264
    Jun 26, 2020
    South Texas
    Then go 3/4 bushing to 45 street elbow to 1.5" barb. A million ways to skin this cat.
    Have you given McMaster Carr a call? Those guys usually have everything.
    Edit: Are you sure it's 1.5" barb? That hose looks more like 3/4" ID.
    ProfessionalNoticer Thanks this.
  11. ClineER
    229
    139
    Apr 27, 2016
    N.E. Oklahoma
    1in fill line is industry standard, I've never seen 1.5 I'd on any truck. A farm supply store will usually have a barb fitting to work. Spray rigs use them so they are normally on stock, atleast every tractor supply and other farm store has them
