When an ABS error light isn't an ABS system problem...
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Farmerbob1, Dec 29, 2018.
  1. Farmerbob1
    Farmerbob1 Road Train Member
    3,685
    5,792
    Jan 17, 2017
    So, I noticed an intermittent ABS light for my trailer. No problem. Probably a loose wire or something.
    I am on I80 for the next day and a half, passing by the Great Lakes, destination eastern PA, so I didnt want to ignore it.
    I am very glad that I decided to stop and have it looked into.
    Turns out that it was not just a loose wire. It was a loose HUB.
    The tech plugged in the machine and read the fault. Right front wheel speed sensor error.
    The lug nuts were tight, but when the tech jacked up the trailer to look at the sensor inside the right front hub, there was a problem.
    The hub itself was loose. The entire right front dually tire assembly was wobbling a few degrees. Enough to see easily.
    Apparently there is absolutely nothing wrong with the ABS system. The problem was that the speed sensor in the hub was intermittently losing track of the position of the hub as the tire rotated and wobbled.
    The left side front axle also has some wobble. Little enough that it is hard to see, but it can still be easily felt.
    An ABS error light might have just kept me from losing a hub at speed.
    That's the last time I even consider ignoring an ABS light for 'just a short trip.'
  3. Farmerbob1
    3,685
    5,792
    Jan 17, 2017
    Well, it's the next day, and the shop has been busy over night.
    I asked them to check the other axle as well, if one axle had severe wear on the wheel bearings, the other might too. I was right to have them check.
    Four wheel bearing assemblies and two slack adjusters for the trailer. I wonder if someone decided to hop a few curbs at speed with this trailer, or something?
    In any case, they expect to be done in a couple hours, so I won't lose much time today.
    Rideandrepair and x1Heavy Thank this.
  4. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,140
    Mar 5, 2016
    White County, Arkansas
    You probably saved some lives.
    Once the company gets a hold of that, they might back track to whoever had that previously.
    It would not be the first wheel or dual assembly that got loose on people over the years.
    Rideandrepair Thanks this.
  5. Rideandrepair
    17,471
    56,674
    Aug 8, 2015
    Loose wheel end wobbling pushed the sensor away from hub. Proper endplay checked with a dial meter 001-005 thousandths. Any more will cause too wide a gap.Make sure the Shop does a proper torque and best to check with dial indicator although few do.
    Farmerbob1 and x1Heavy Thank this.
  6. x1Heavy
    34,016
    42,140
    Mar 5, 2016
    Don't forget the roller bearings if any back there.
  7. Farmerbob1
    3,685
    5,792
    Jan 17, 2017
    Service was finished at around 10 AM. I drove a while, then stopped for a retorque on all four wheel assemblies.
    No ABS light codes after the first 50 feet of movement.
    All seems well. About 500 miles today with no detectable issues.
  8. sask3500
    sask3500 Bobtail Member
    12
    Jun 19, 2017
    I’ve had that on a drive axle as well, no abs light at less than 70km/h. At low speeds the tone ring contacted the sensor, at high speed centrifugal force straightened the wheels up and opened the gap up setting a code. Set bearings, no problems.
    Farmerbob1 Thanks this.
  9. tnpete
    tnpete Medium Load Member
    561
    609
    Jun 25, 2013
    Tn
    Found a bad steer axle bearing in 1994. ABS light came on 5 miles from the Yard. Told the shop about it when we rolled in. Was running team, so we were putting 7K per week on it.
    We came back in 4 hours later to leave out again. And they were finishing it up. Told us the clearance opened up. Allowing the ABS to show a warning light.
  10. Fred75943
    Fred75943 Bobtail Member
    21
    Oct 11, 2017
    Same issue, but I had damage to my spindle. They had to weld it and machine it down to tolerances.
