When to do a overhead run?
Discussion in 'Ask An Owner Operator' started by dphillips, Jul 25, 2017.
  1. dphillips
    dphillips Light Load Member
    82
    8
    May 14, 2013
    I spoke to a mechanic today and he said you should do an overhead every 100 thousand miles. I asked 2 other shops and they both said you shouldn't do it until you need it it's going to make things worse. Which is correct?
    Lepton1 Thanks this.
  3. fargonaz
    fargonaz Road Train Member
    1,167
    4,583
    Feb 9, 2015
    Mesa, AZ
    I do it once a year(~100K) on my ISX. It can't hurt anything except your wallet, if it wasn't required.
    magoo68 Thanks this.
  4. redoctober83
    redoctober83 Road Train Member
    2,407
    2,291
    Sep 10, 2013
    Seattle, wa
    What does the owners manual say for your truck? My 2015 freightliner owners manual says every 100k miles.
  5. dphillips
    82
    8
    May 14, 2013
    Man I haven't seen that thing since 2012
  6. Ridgeline
    22,723
    123,050
    It won't hurt a thing, every 125k is what we do.
  7. MOGLAR
    MOGLAR Heavy Load Member
    743
    518
    Jun 19, 2013
    Kansas City , MO
    When your oil samples indicate you should do one....not until.
  8. MOGLAR
    743
    518
    Jun 19, 2013
    Kansas City , MO
    I hope you are doing oil samples (the ones that actually go to a Lab). It is only $18.00 You will be e-mailed the results. I do a sample EVERY oil change.
  9. snowwy
    snowwy Road Train Member
    20,611
    13,326
    Jul 6, 2009
    The 2016 FL didn't have anything in the manual for overheads. And i was the first driver in that truck. The 2012 never got one done either. While i was in that truck.
  10. RStewart
    RStewart Road Train Member
    3,165
    5,041
    Aug 21, 2015
    Norman, OK
    My 2016 & 2011 freightliner DD15 both said to do it at 150,000 & then every 500,000 after that.
    uncleal13 and magoo68 Thank this.
  11. DougA
    DougA Road Train Member
    1,429
    8,892
    Dec 16, 2013
    Retired,In my shop in Md.
    Oil sample won't tell you anything about overhead.Overhaul,yeah.
