Why do you even pull reefers?
Discussion in 'Refrigerated Trucking Forum' started by scoobertdoo, Jul 31, 2023.
  1. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,603
    Nov 11, 2020
    For two years I pulled a reefer.
    Prior to this I ran rgn and landoll in the north east. Typically crane loaded or I drove it or winched it on myself. I could be in, chained up and out in less than 45 minutes.
    So I went reefer. The rates were amazing so the 4-6 hour load times, 3-14 hour unload times were worth it. Then the spot market crashed. I made the assumption this is just how boxes are.
    Now I have been doing van for 3 weeks, and it's the best 3 weeks of my life (stress and drama wise, not money)
    Typically I am loaded or unloaded in less than 1 hour, as long as I am not too early. No worry about the reefer breaking down, wrong temperature, count, brix level, product loading temp, or if the trailer will be rejected for being a loose definition of "dirty".
    Basically unless I screw up the driving or fail to secure the load, I'm fine.
    So why, in a down market, do you even bother with reefer?
    I get it, when I could get $3-5 a mile it's worth it... But the loading/unloading time is complete crap.
  3. rollin coal
    rollin coal Road Train Member
    13,668
    28,124
    Mar 29, 2008
    TN
    Because van rates are mostly garbage. I did 6 years of pulling a van off the spot market and 7 pulling a reefer. I'd pick reefer given a choice.
  4. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,750
    16,653
    Jan 18, 2011
    Truck averages 7k a week on less than 1k miles
    Life’s good
  5. D.Tibbitt
    157,356
    man you musta really hated open deck if you can put up with dragging a box around.
  6. scoobertdoo
    1,512
    2,603
    Nov 11, 2020
    I went to Vegas once to pickup some equipment. Before I was done with the chains I was in heat stroke. Other times of the year you freeze, and ice coats everything.
    Money was great but in my new Florida market, it's not like it was when I had Newark, and all the constant heavy equipment that they would haul into the port/out of the port. I looked into landoll down in FL, I might as well go work for Sunbelt instead of buying one.
  7. pavrom
    pavrom Road Train Member
    3,224
    7,461
    Apr 29, 2012
    NE illinois
    ...i wish i had these type contacts:)
  8. Concorde
    Concorde Road Train Member
    5,506
    19,599
    Jun 29, 2016
    West Melbourne Florida
    Spot Van rates vs reefer really ain’t much if any difference in rates.
    I’ve looked into going back doing reefer but for an extra ten cents? lol
    After reefer fuel, washouts, maintenance and time lost sitting at the docks I highly doubt that pulling a reefer today will make more than a van.
  9. mjd4277
    mjd4277 Road Train Member
    14,772
    45,601
    Oct 4, 2015
    Fitchburg,MA
    Have had “reefer madness” for seven years now with my current employer. Haven’t looked back since. The pay is certainly better than dry van-too many drivers have saturated that market and as a result,there’s not enough dry freight to go around.
    Rookie driver 956 and bryan21384 Thank this.
  10. Concorde
    5,506
    19,599
    Jun 29, 2016
    I’m still getting $3+ on some of my long haul van loads.. not all but some.
    Did around $7,500 gross this week..
    Rookie driver 956 and Siinman Thank this.
  11. ‘Olhand
    6,750
    16,653
    Jan 18, 2011
    On how many miles??
