Winter idling
Discussion in 'Ask An Owner Operator' started by Drsparkey3, Feb 14, 2020.
  1. Drsparkey3
    Drsparkey3 Bobtail Member
    35
    28
    Nov 30, 2019
    I know it's not a good idea to idle with these epa10 engines, but what about when it's below zero? Does that harm the engine or the after-treatment?
  3. Doealex
    Doealex Medium Load Member
    597
    1,132
    Feb 21, 2018
    No more harming than gelled up diesel/not cranking engine in the morning.
    PE_T, mhyn and magoo68 Thank this.
  4. MGE Dawn
    MGE Dawn Road Train Member
    1,098
    2,294
    May 19, 2019
    Vancouver, WA
    Between clogging the DPF and letting the fuel gel, I'll take a clogged DPF any day of the week, twice on Sunday. Even with winterization, cold enough weather can and does gel the fuel
    magoo68 Thanks this.
  5. Doealex
    597
    1,132
    Feb 21, 2018
  6. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,143
    Mar 5, 2016
    White County, Arkansas
    Your fuel returns should keep the tanks toasty relatively.
    I run the engine in anything below 10 above. Particularly -20 and below. PRe emissions time I have never had a engine give trouble when running all the way down to -55 local temps although it's clear the rig is having a form of arthritis due to the lube oils and many temps being colder than usual. We have had experienced temperaturs inside the cab and sleeper into the 50's, warped cab doors and so on.
  7. Brandt
    Brandt Road Train Member
    4,620
    6,349
    Sep 17, 2012
    They have the DPF filters I would say figured out today. The DPF is working at idle and at highway speed. It's catching all the soot. When idling it fills up and the computers do a parked Regen by pumping diesel into exhaust and lighting it on fire to get the DPF upto 800f-1,000f
    It does the same thing going down the road. Now the engine and exhaust gas is already hot enough to keep the DPF hot and burn all the soot all day as your driving. The first engines with DPF like the old S60 always would put oil and diesel into the exhaust when you idle them. That would mess up the DPF. The new emissions engines don't do that. Now the truck even do automatic parked Regen. They don't wait till the DPF is so full. The Freightliner just does it every 6 hours of idling.
    Frontman Thanks this.
  8. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Well if it's idle or freeze I know my choice.
  9. Judge
    91,574
    You go sleep in the drivers lounge?
    Def will freeze too.
    Idle wont hurt, can fast idle to bump up the oil pressure, it’ll regen if needed.
    flood Thanks this.
