wyoming permits
Discussion in 'Experienced Truckers' Advice' started by D.Tibbitt, Jul 10, 2023.
  1. D.Tibbitt
    156,783
    any of you more experienced hands that have dealt with wyoming and running oversize can help me out here? what is the process to get permits in wyoming? i have a easy 11-6 wide legal weight and height load headed westbound i-90. ended up routing myself up thru bfe north dakota then to montana instead because i dont really understand what is required when entering wyoming and didnt wanna get stuck. the way i read their website you have to call ahead to the port of entry and get a secret password, and then they issue you permits at the poe? is that right? ballpark cost for what a legal weight overwidth permit would cost for wyoming? routing thru ND cost 30 bucks and 100 extra miles.. any experienced info for wyoming and insider information is appreciated. thanks
    singlescrewshaker and motocross25 Thank this.
  3. Moosetek13
    Moosetek13 Road Train Member
    14,957
    18,972
    Nov 1, 2010
    Burnsville, MN
    If you call ahead to the port of entry, couldn't you ask them all these questions?
    They would have the correct answers, by the way.
    D.Tibbitt and tscottme Thank this.
  4. blairandgretchen
    13,917
    76,459
    Dec 9, 2011
    South west Missouri
    Call the POE 24 hrs ahead, have all your dims and numbers ready. They’ll enter it in and give you a number.
    Drop in, go inside, work out a route, should be $27.25.
    I’ve found them very polite and helpful.
  5. D.Tibbitt
    156,783
    Very much appreciated sir.
  6. Cat sdp
    Cat sdp . .
    21,282
    76,023
    Apr 8, 2012
    Orion's Belt
    See how easy that was……
  7. Long FLD
    Long FLD Road Train Member
    12,824
    53,655
    Mar 4, 2015
    They are picky about the measurements too. We used to haul beams and joists out of OR out to Casper and would always just tell them the material was 60 foot. Well that worked great until someone at Evanston went out and measured one of our trucks and figured out the beams were anywhere from 60’3” to 60’5”. So we had to start measuring the beams so we could give them the exact length of the longest one.
    Wyoming is stupid about a lot of things.
    IH9300SBA, beastr123, Siinman and 2 others Thank this.
  8. Jubal Early Times
    3,069
    20,586
    Oct 17, 2022
    It’s more expensive for weight but the process is the same
  9. Jubal Early Times
    3,069
    20,586
    Oct 17, 2022
    Need dimensions weight and axle spacing
  10. Jubal Early Times
    3,069
    20,586
    Oct 17, 2022
    Also you don’t have to call 24 hours ahead, but I suggest at least two
  11. Rontonio
    Rontonio Road Train Member
    6,483
    47,863
    Aug 9, 2009
    couple other things you need to know (they are more than willing to give a financial reminder…)
    first, the pre clearance number is a must. If you are buying weight as 5 or 6 axle pad the weight you ask as they will weigh/measure you every time. They only charge for what they weigh you at.
    second, have all you axles on the ground and if you have a flip axle have it on the ground. This will make your life easier.
    Third, you must always weigh before parking - do not go to the job-scale side of the scale house. They can/May write you a ticket for not following the instructions.
    Last, know in advance of you are going to require a pilot car or two. You are expected to run fr the state line or loading location to the scale WITH your required pilot cars or again - possible doom.
    there are other steps if you are going to fall into the super load category but mostly as 5/6 axle you won’t need it.
    hope this helps - they are not always a holes - keep a good positive attitude and it will likely go well.
