0 air pressure to truck, help would be greatly appreciated and DPF issue
Discussion in 'Ask An Owner Operator' started by hilliard, Sep 5, 2015.
  1. simon999
    simon999 Light Load Member
    240
    95
    Feb 6, 2014
    You dont have to change compressor unless its worn and not building fast enough air. Just replace unloader
    hilliard Thanks this.
  3. simon999
    240
    95
    Feb 6, 2014
    This worst thing to do to clean with pressure water!!it helps for while but later your dpf will be gone!instead of paying to bake it and proper way, now will have to replace it
  4. AModelCat
    160,354
    Sad thing was it was the company maintenance manager that told us to do it. Instead of buying the proper gear to do the job or sending it out to get done, they'd rather half-### it and spend more in the long run.
  5. xsetra
    xsetra Road Train Member
    5,130
    7,024
    Aug 21, 2011
    Maybe he doesn't know. Just sayin.
    Hillard glad to hear you found the problem. Easier to see in the light of day. Like others said. Thread lock/sealant put it together and use it that way. If its building enough air fast enough everything is fine. Just one more thing to check for a while.
  6. AModelCat
    160,354
    Oh he knew everything. We used to call him God behind his back lol.
    icsheeple and hilliard Thank this.
  7. hilliard
    hilliard Light Load Member
    78
    61
    Sep 13, 2009
    hilliard, oh
    Will buy a new unloader to be on safe side. Thanks again everyone.
    Would putting the white plumbers sealant tape work?
  8. AModelCat
    160,354
    I've used that on pipe threads. Works just fine. I prefer the non-hardening ptfe paste myself though.
  9. 77fib77
    77fib77 Road Train Member
    10,768
    68,346
    Jul 7, 2010
    St Louis
    If it is threaded just use Teflon tape to make it stick better.
