I'll try to make this make sense. Last night I discovered an issue on accident. I've had a jumper wire between the brown and black wires on the trailer plug for sometime. (Pulling a bullrack occasionally when I turned the inside lights on it would trip the breaker, putting a jumper between the brown and black would help with this. Last night doing some work I had the trailer cord unplugged from the truck and turned the clearance lights on I only had half my normal clearance lights and if I had the headlight switch turned on it defaults to high beams only(something peterbilt does when something isn't right. Plug the trailer cord back in and everything goes back to normal (the jumper wire between brown and black is used when cord is plugged in.
So basically I don't have power on the black wire only on brown at the trailer cord and only half my marker/clearance lights on the truck work and it causes some strange problem with headlights too. If I jump brown and black at trailer plug everything works fine.
I'm stumped. Ive checked everything in the fuse panel and clearance and marker lights don't have a different designation anyway. Help me if any of this makes sense to anyone.
I hope I was clear as mud. This is without a trailer hooked up.
01 379 electrical problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by lester, Apr 7, 2018.
We had one doing something similar though we never jumped the black and brown wire. I just remember the tail lights not working and the headlights default to high beams.
In the fuse box a 5 prong relay wasn't getting connection. I remember it was toward the bottom kinda. I think it was marked CL lights or marker lights -
The only time my 379 went into default high beam mode was when the turn signal switch was failing, the stop and taillights both pass through the turn signal switch on a 2001 379 (but not the marker lights)
If the problem disappears when the trailer is connected it sounds like the jump wire is feeding power back through the system to the sensor that activates the default high beam so it thinks everything is fine, once the trailer is disconnected that power can only come from the taillight circuit; if it is bad in the turn signal switch it will not make it to the sensor and the high beams will come on.
If all fuses and relays are clean and functional the turn signal switch is where I would look next.Last edited: Apr 7, 2018
Oxbow Thanks this. -
Oxbow Thanks this.
Oxbow Thanks this.
Turns out it was a relay that wasn't getting good connection. Don't know why I didn't check it better Friday night I've had trouble with this one before.
It was a frustrating weekend. Going to start pulling a different type trailer so I was installing a wet kit this weekend (60gpm hyd pump) .Not cheap. Pulled the bottom cover off transmission and feel around a little bit. Definitely have a bearing going bad, way to much slop and silver in the oil. But filled it with fresh oil, hope to get a little more time out of it. Oh the joys of an older truck . just overhauled engine this winter and I have a rear end gpnng need work soon to.
I know the timing is tough right now but if the transmission is starting to drop metal pieces they will likely find the lowest point, which is now your new PTO.
If there is any way to do the transmission replacement now it might save you buying a new PTO later.
Good luck, sorry to hear things are piling up on you.Last edited: Apr 8, 2018
wore out Thanks this.
