Code 31: Aux. High Side Output Open Circuit or Short to Ground
What is that referring to? Code flashed momentarily under braking -- has not appeared before and is not currently triggering a fault...
'01 9400 12.7 flash code 31
Discussion in 'International Forum' started by double yellow, Dec 9, 2015.
What is the auxilary output?
blairandgretchen Thanks this. -
Hello,
I know this post is old but, did you find out what the issue was?
I do have this fault code and am curious what the problem was.
Thanks -
Output for the engine brake solenoids. ECM is detecting an open or short in the circuit.
