Was hooking up accidently touched the two together. .. can't find fuse to change anywhere 01 volvo power supply studs
The inside of the fuse panel has a label that tells you what each fuse is for. Slide the drink holder out and you will find two torx screws and you must remove those screws and lift the panel from the dash to get to the fuse panel
