Help me please! I have searched and searched and can't find a post to help me. 2002 9400i, Heater blower motor quit working. I checked the fuses, only found one "breaker"; it had not tripped. I replaced the blower motor and resistor. still dosen't work. When i move the fan speed dial, I hear clicking from a relay behind the glove box. I need to know what else to check. Am I missing something? I am at the end of my rope, and my feet are cold. Thanks in advance.
'02 9400 blower not working
Discussion in 'International Forum' started by silver dollar, Mar 13, 2014.
Here is lots of information for you;
http://www.thetruckersreport.com/tr...147619-05-9400i-blower-motor-replace-how.html -
Could be the resistor if it has one. I had a car do that to me before
The resistor only effects the lower speeds. High speed is direct 12 volts through different circuits.
I found my problem. Hi speed fan relay (bottom, 2nd from left) socket melted.
Is this socket base replacable, or do I have to replace the whole fuse panel? -
Those little socket blocks are replaceable. They interlock like Legos so you will have take a lot apart, but it is doable. Part number for the little block is 0593385C1
silver dollar Thanks this. -
