03’ 9900 clutch fan engages very frequently
Discussion in 'International Forum' started by Dadetrucking305, May 24, 2021.
  1. Dadetrucking305
    Dadetrucking305 Heavy Load Member
    983
    2,583
    Sep 15, 2011
    Cibolo,Texas
    The clutch fan on my truck engages frequently and I have counted 3-5 seconds in between intervals.What can be causing this?
  3. kemosabi49
    10,548
    45,092
    Jan 13, 2013
    SW Arkansas
    An '03 Columbia I was driving started doing that when I was running the a/c. Wan't getting enough air flow through the condenser. Had to evac the A/c, remove the condenser, take the hoses off the air cooler and separate it from the radiator. Then the mechanic blew it all out. Ended up with the floor covered 1/2" deep with crap that came out of there. Put it all back together, charged the a/c and no more problem.
    I had tried blow the whole thing out before, but because it had been so many years since it was really cleaned i just ended up packing the crap in there more.
    Dadetrucking305 Thanks this.
  4. Dadetrucking305
    983
    2,583
    Sep 15, 2011
    Cibolo,Texas
    Changed out the high pressure switch/sensor and it’s still doing it.
  5. ChuckMartel
    ChuckMartel Light Load Member
    160
    94
    Jan 22, 2021
    Is it kicking at a certain temp? Only when AC is on?
  6. Big Road Skateboard
    6,057
    32,856
    May 2, 2021
    Turn the a/c off. It's likely building head pressure, turning on the fan, head pressure comes down, fan goesoff
  7. Dadetrucking305
    983
    2,583
    Sep 15, 2011
    Cibolo,Texas
    Hadn’t thought about the A/C but I just tested it and sure enough that’s what’s causing it to come on.So what could be wrong with the A/C?
  8. God prefers Diesels
    4,198
    22,259
    Jun 26, 2020
    South Texas
    It's supposed to do that. The condensor has to have air flow. So if you aren't moving, the fan has to come on when the pressure gets high enough to trip the switch. It will do the same thing if you're running the defroster.
  9. Dadetrucking305
    983
    2,583
    Sep 15, 2011
    Cibolo,Texas
    It’s doing it while I’m driving.
    God prefers Diesels Thanks this.
  10. God prefers Diesels
    4,198
    22,259
    Jun 26, 2020
    South Texas
    Oh hell, it shouldn't be doing that. Could be something as simple as being low on freon.
    @Rideandrepair is pretty good with A/C, as well as several others, but he's the one I remember going really in depth recently.
  11. Dadetrucking305
    983
    2,583
    Sep 15, 2011
    Cibolo,Texas
    I changed the high pressure switch/sensor and purchased Freon bottle and it showed that the truck was full.
