03 C 15 bridge motor only making about 18lbs of boost
Discussion in 'Trucks [ Eighteen Wheelers ]' started by skytrends, Apr 17, 2013.
  1. skytrends
    skytrends Light Load Member
    63
    25
    Jan 1, 2010
    Culpeper, VA
    Just bought this truck last month motor recently overhauled. Runs ok but only makes about 18lbs of boost and builds slowly. Could the low boost be the boost pressure switch? or where should I be looking? Thanks
  3. billandlori
    billandlori Medium Load Member
    357
    107
    Sep 5, 2010
    Stratford, Ontario, Canada
    Could be a stuck waste gate or a pretty bad leak in your CAC or flex boots.
    Should help your MPG a bunch to get the boost back up!!
    Bill
  4. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,041
    Dec 17, 2008
    It could be any number of things.
    exhaust sleeve broke and has damaged the turbo
    electronic wastegate controller not functioning properly.
    boost leak at aftercooler or hoses.
    You also should flash the ECM with an earlier file for much better fuel mileage and Hp
