03 Peterbilt 379L with dust problem in cab
Discussion in 'Peterbilt Forum' started by wilson007, Oct 18, 2009.
  1. wilson007
    wilson007 Bobtail Member
    Shaunavon , SK
    Anyone have an idea as to why my truck is leaking dust into the cab and bunk? I have changed all my cab filters and weather stripping, what am I missing? Most of the dust is coming through the heater vents.
  3. haystack
    haystack Light Load Member
    177
    22
    Feb 12, 2009
    There is a hose that lets the condensation run out, check to make sure it has a loop in it.
  4. blackw900
    blackw900 The Grandfather of Flatbed
    5,817
    7,678
    Jul 12, 2009
    A.W.O.L
    Never, Ever leave the fresh air vent open! I don't care what filter you use they let a ton of dust through! The day I buy a truck I take it home and seal the fresh air vent closed.
    If I need fresh air I crack a window down.
  5. Harley Tramp
    Harley Tramp Bobtail Member
    13
    Aug 28, 2013
    Had the same problem. It was the actuator motor that open and closes the fresh air door behind the air cleaner. It was open all the time. Check to make sure door is closed. I leave mine in recirculate all the time. No more problems
  6. Luwi67
    Luwi67 Heavy Load Member
    749
    484
    Oct 24, 2012
    Long island
    I had the same problem too but, not so much with dust, I was having problems keeping my windows defrosted. Turns out the rivets that hold fresh air door on the shaft corroded and the door actually fell off the shaft. Had to remove the air cleaner and pull everything apart to get the shaft and door out. I then spot welded the door to the shaft to hopefully keep this from happening again. Defroster works great again.
