What you had was an "OPEN" (burned fuse) not a "SHORT".. having said that, a momentary short may have over loaded the fuse..
Never over fuse a circuit, what ever burned the fuse this time may melt the wire the next(with larger fuse)..
... Philip
04 387 side lights not workin on truck and trailer any help can't find a fuse for it
Discussion in 'Peterbilt Forum' started by Gator387, May 6, 2015.
Page 2 of 2
Not smart what you did!!!! You still have a problem most likely. Put the right fuse back in. If it still blows you have a short. If you leave that bigger fuse in you may start to melt wires or cause a fire.
Gator387 Thanks this. -
Well the reason I got a slightly bigger fuse in it is because I got a bunch of light running out of the circuit
Replace the fuse with a rated circuit breaker, it will protect the truck and reset once the load is off..
best of both worlds...
...PhilipGator387 Thanks this. -
Well I took my truck back to the shop that had worked on it last time for the same issue and I had a shop foreman work on it and he found two exposed wires rubbing together and he got that fix now I got all my lights working , feeling good
Easy when you know how!!
Glad she is fixed..
.... Philip
Page 2 of 2
