04 670 D12 mechanical fuel supply code/no start
Discussion in 'Volvo Forum' started by IUFAN87, Jan 21, 2013.
  1. IUFAN87
    IUFAN87 Light Load Member
    220
    31
    Jun 22, 2009
    All Over
    My 04 670 with D12 has been running flawlessly. I went to start it after it had been sitting a couple hours. It cranked longer than normal before it finally started. It ran rough and set the mechanical fuel pressure code. I let it idle a couple minutes and shut it off. Now it wont start at all.
    Im guessing that the fuel supply pump has gone bad. I thought it was possibly just the water separator filter clogged, but not likely since it happened so suddenly. Any ideas on what I can check that could be the problem?
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    start with cheap stuff, like filters, fuel lines... and if all this cheap stuff is good - remove, inspect and may be replace fuel pump
    IUFAN87 Thanks this.
  4. IUFAN87
    220
    31
    Jun 22, 2009
    All Over
    Thanks for the reply pablo. The volvo dealer replaced the filter but that didnt fix it. It ended up bein the piece that drives the pump. The bearings went bad in it and damaged the pump. They fixed it all up for me.
