04 pete 379 mbn or 6nz????
Discussion in 'Trucks [ Eighteen Wheelers ]' started by dpfndefbad, Mar 21, 2013.
  1. dpfndefbad
    dpfndefbad Bobtail Member
    35
    Oct 31, 2012
    PA
    Looking at a Pete but its in Oregon and I'm in Pennsylvania. It was rolled on its side and crushed cab and hood. Waiting for vin number but wondered if anyone knows when they switched from the 6nz to mbn? Is the mbn as good as 6nz?
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    only if you unbridge the mbn. more than likely it's an mbn being an 04.
  4. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    pretty sure o3 was the last 6nz
  5. dpfndefbad
    35
    Oct 31, 2012
    PA
    Yeah was thinking 03 but my 00 Pete is titled as 00 but has 99 manufactured date and a 2ws under the hood. How do you Tunbridge the mbn and how much?
  6. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    just flash the ecm to a 6nz file and deal with the wastegate line the cam an injectors are diff but can be used with the 6nz file till ya get money for the swap get ahold of haney he can do the ecm for you
  7. underpsi
    underpsi Road Train Member
    1,266
    292
    Sep 18, 2008
    Toronto, Ont
    Could be an MBN or a BXS Acert. 2WS are most commonly used in 2000, 6NZ was introduced in 2001 I believe.
  8. HISPEED428
    HISPEED428 Light Load Member
    157
    21
    Mar 28, 2009
    Plum Coulee,MB
    iirc back in 99 you could spec either a 2WS or a 6NZ.
  9. CatPowerC15
    CatPowerC15 Medium Load Member
    347
    90
    Feb 18, 2010
    Siler City, NC
    One of my W9's is stamped 12/99 and its 6NZ.....also have one stamped 12/02 and its MBN.
  10. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    The classic we just picked up is a early 2000 and it has a 6nz in it, the serial is 3251 so there are some early ones out there.
  11. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    my 6nz is 2003 serial 77988
