04 T2000 no power to center abs/aux pin please help
Discussion in 'Kenworth Forum' started by greenmile_08, Jan 21, 2015.
  1. greenmile_08
    greenmile_08 Light Load Member
    88
    17
    Feb 5, 2013
    eagle bend, mn
    Hello everyone looking for a little help, I've checked fuses behind glove box although no manual so checked all . All seem to be fine , stripped away the plastic coil to the female pig tail on tractor all wires and connections good .
    No power there , it's got to be a fuse or corroded wire somewhere , I've looked on the fire wall like the w9 but no luck am I missing something ? Also a nice clear pic of fuse panel diagram would be awesome.. any help is appreciated thanks
  3. greenmile_08
    88
    17
    Feb 5, 2013
    eagle bend, mn
    So far 141 fellow truckers and not a one has a better thought at it then I lol.... Someone else is gotta own one of these amazing miracles of kenworth ingenuity ...Ok I'm gonna stop before I hurt myself
  4. bigguns
    bigguns Road Train Member
    2,846
    6,854
    Jun 13, 2013
    Omega,GA
    Find the 7 way trailer cord where it connects to the firewall. Check for power coming thru the firewall. Use an ohm meter to determine is the wire for the center post has continuity from the firewall to the trailer plug. You are probably looking for a 25 amp fuse. The fuse could be blown and still look okay. Test it with the ohmmeter.
  5. RSQ20
    RSQ20 Medium Load Member
    Or, use a tone generator, (non destructive test)....
    ... Philip
  6. greenmile_08
    88
    17
    Feb 5, 2013
    eagle bend, mn
    Thanks for the response was hoping that maybe I just overlooked a hidden fuse or something cause tracing that up the frame rail and through everything outside in 10 degree weather ...but if nobody has any other ideas I'll get to it
  7. greenmile_08
    88
    17
    Feb 5, 2013
    eagle bend, mn
    Well I believe I found my problem after rechecking all my fuses ,( all were good) I found in the bottom right a empty slot for a fuse I guess I must have overlooked it as it was dirty to the point you really couldn't tell it was a fuse slot . Anyways put new fuse in there no more problems.. would be nice if someone with a t2000 could give me a fuse layout pic .. that's clearly visible , would be greatly appreciated
  8. bigguns
    2,846
    6,854
    Jun 13, 2013
    Omega,GA
    Ain't that sumthin. Glad you figured it out.
