04 Volvo D12 A/C problem
Discussion in 'Volvo Forum' started by Rustywolf, Aug 12, 2012.
  1. Rustywolf
    Rustywolf Bobtail Member
    23
    Apr 24, 2012
    Otisfield, Maine
    My compressor bearings froze up and broke the belt. I had the compressor and belt replaced and the dryer. My A/C still doesn't work. If i jump the compressor with a hot wire it works fine. But when i connect it to the harness i get a code saying the unit is bad.
    Is there a reset for this or could a senser go bad when the compressor did? Had great A/C before.:Wrench:
  3. SneakyAdvertiser
    SneakyAdvertiser Bobtail Member
    7
    Aug 30, 2012
    Which compressor did you buy? On some updated compressors that Volvo sells, there is also an attachment harness that comes along with that. Was that installed ? If not there might be an issue with the compressor wiring.
    Can you also provide codes under the climate control section, on the dash.
    Hope i can help ya!
