04 w900 overhead panel replaceable lights?
Discussion in 'Kenworth Forum' started by circle h, Jul 17, 2021.
  1. circle h
    circle h Light Load Member
    240
    375
    Oct 22, 2020
    The low air warning light on the overhead panel does not illuminate. Not even in the key cycle light check. The low air buzzer, which is way to loud, works fine. Has anyone changed a bulb in one of these? Anyone have any idea what all the dip switches do? Thanks for looking.
  3. Cummins_444
    Cummins_444 Medium Load Member
    605
    1,014
    Apr 28, 2008
    Northwest, IN
    To change the bulbs. Remove the screws from the circuit board. Then it will come apart to get to the bulbs. The little switches turn the buzzer on and off for the different warning lights.
    Oxbow, w9l and spsauerland Thank this.
  4. circle h
    240
    375
    Oct 22, 2020
    Thanks for the reply, I found a diagram right on the side of it that tells which functions are changed with the dip switches.
    Oxbow Thanks this.
