04westernstar air pressure gauge
Discussion in 'Western Star Forum' started by loghauler72, Feb 3, 2014.
  1. loghauler72
    loghauler72 Bobtail Member
    My 04 western star resvoir a gauge reads 40psi all the time with no change its electric I have been tog a valve is out
  3. RockBucket
    RockBucket Bobtail Member
    24
    Apr 1, 2013
    A valve out? What valve? I would be more inclined to think a bad gauge or sending unit. Not saying it couldn't be a valve, I just don't understand what valve. I also have a 94 WS 4964EX. Love it. I made a bobtail dump out of it 11 years ago. Helluva truck.
  4. underpsi
    underpsi Road Train Member
    1,266
    292
    Sep 18, 2008
    Toronto, Ont
    Problem is your truck most likely has the multiplex gauge systems which means its a lot harder to fix when something gos wrong. It could be the gauge, wiring, communication box, signal line...
    Cetane+ Thanks this.
  5. danezu
    danezu Bobtail Member
    6
    Apr 22, 2014
    It's more than likely your gauge. The good thing is, it is very easy to replace and shouldn't be very expensive.
    However just for peace of mind you might check this:
    Make sure your low air buzzer is working, should come on at about 80 psi.
    When the low pressure buzzer is not on, you have more than 40 psi.
    If you have an analog gauge there is a small air line on the back of the gauge; when you unplug it you should have air blowing. If you don't have air coming out you have an airing problem. If you have a digital gauge it reads frequency generated by the RX Module. The RX module converts the air pressure to frequency. There should be a 1/4 inch line going to the module(located under the Lh cab leg). If there is no air on it again you have an airing issue.
    Hint : you might have to drain the A system in order to unplug the line at the RX module
    There is no valve to control the gauge.
