Anyone can tell me where the 05 379 city horn is located under the hood?
I looked all over the fire wall and havent seen it
It's not working and new company requires it to pass inspection to start work
05 379 city horn location
Discussion in 'Peterbilt Forum' started by Cajuncowboy654, Jul 3, 2019.
Someone probably took it off. Center of the firewall is the correct factory location.
Cam Roberts and Coolbreezin Thank this. -
I was afraid of that. Did find 2 wire near the top that were just there going to a plug to the driver side
yes as goody snap said.
Center of fire wall close to the starter relay. I own 379. If someone cut the wires, they should be close by. I have to run my overhead tomorrow, so ill look to see where the wires are coming from and post a picture on here.Goodysnap Thanks this. -
Ok I'm pretty sure those are the wires I found. They were just sitting there a little past the starter relay.
I will hook up a new horn and try it out
