I have a 2005 379 X 475hp 18spd 3.36 11.22.5 rubber 244 wb. approx 875,000 miles. when I go down the road BT the seat, buck vibrates (thumps ) all most like the drives are hopping back and forth. it is less when I have a trailer hooked, and less when loaded, yet you can always feel it approx 50 mph, and 65 mph. I have replaced rear drives, ALL shocks, centromatics on all wheels, torch bars on the drives and set the air susp, steers. if it helps the tread is wearing in a stepping pattern. If you look across the top of the tire you can see stepping in the tread. they all have been checked for roundness. I do pull heavy loads, 135,000 gross, the truck goes through an in house shop inspection every 60 days. Not sure if the wear on the clutch,
Please help me . I cant find any C4 or that would fix my issues !
05 379X bad bounce down going down the road
Discussion in 'Peterbilt Forum' started by BigNbulky, Jun 9, 2013.
Your description is bang-on for something out of round with one of the drives. When I encounter a complaint like this I put both drive axles up on jack stands and run the truck to speed in the shop. You will find one or more tires bouncing. I know you said the tires have been checked for roundness, but it takes so little out of round to cause a big shake! You really need to see how the tires are rolling with those axles jacked up. Tires can be mis-mounted on the rim, so the whole wheel is spinning out of round. Rims can be slightly off center on the hub, and this also causes the wheel to spin out of round. Centramatics will do nothing for you, they are only for fine tuning the balance of a wheel that is running true. The tread wear pattern may simply be the wrong tread design for your application and rarely to blame for the type of shake you are describing.
I have had the truck up on stands and turned the drives and they all appear to spin round. The tire guy suggested turning the outside tires a 1/4 - 1/2 turn on the rim.
How did you turn them, by hand?
Yes. He did them by hand.
When you spin the tires, also check for a bent rim. Alum rims bend just like steel, happened on one of my steers.
I had a cracked pressure plate did that once. It was funny to find it out even but some oldtimer knew what it was.
Ok, thank you , I will try that.
Sounds like C4½ may be required.
Stationary & spinning, don't overlook the driveshaft or any other rotational items. Also, have you made sure your bags have proper inflation and height valve is functioning as it should? Just slingin' out some thoughts.
