'05 387 LF Marker Light Issue
Discussion in 'Questions From New Drivers' started by EverywhereMan, Jan 24, 2014.
  1. EverywhereMan
    EverywhereMan Medium Load Member
    303
    391
    May 28, 2013
    The North
    Alright, this might seem like a dumb question, but I'm having an issue with the marker lights on my drivers side headlight assembly. The turn indicators are working, but I'm not getting any marker/parking lights at all on the driver side. Passenger side is working fine. I tried checking the fuse box but I'm not seeing anything out of the ordinary. I changed the inner most amber bulb two days ago and noticed the marker lights were flickering briefly. I tried checking the wiring and the bulbs after that and they seemed fine. Advice? Should I be re-checking the fuse box and/or wiring to the lamps?
    *Mods: I have copied this thread from the Peterbilt forum where it has received no responses. You may close that thread as I figure I will be more likely to get a response here. Thank you.
  3. Mountain Hummingbird
    Mountain Hummingbird Medium Load Member
    601
    399
    Oct 14, 2012
    If you have power then it is not the fuse box, check for a good clean ground, ground issues are the most common electrical issue for trucks.
