05 387 manual window regulator, convert to power?
Discussion in 'Peterbilt Forum' started by Steve from hutch, Jan 12, 2019.
  1. Steve from hutch
    Steve from hutch Medium Load Member
    My 05 387 has a crank window on the pass door, I want to change it to power. The wiring is at the door for the power regulator, is this a straight swap?
    Where can I get switches for the swap, door switches seem to be elusive in the aftermarket?
    Thanks,
    Steve
  3. snowman_w900
    4,418
    81,025
    Nov 25, 2010
    I still have a T2000 that I parted out Steve. I was told the door was the same door as the 387, but I cant confirm it. Maybe someone here could confirm it.
    If so, you would be welcome to any parts that might help you. The interior and cab is in really good shape on the T2000
    SAR Thanks this.
  4. Steve from hutch
    The doors ARE the same on the T2 and 387, that is a fantastic offer. I will send a PM
    snowman_w900 Thanks this.
