05,9400,isx,cm870. no codes. Intermittent throttle response after shifting to hi range. works fine in lo range. However,sitting in the shop everything works fine but insite shows 15sec delay for tps,cruise on/off,clutch release/depressed. Insttalled a test ecm. no change. clutch does not kick off cruise or hi idle. only brake pedal will. Stop eng light flickers.
05 9400 isx sporadic throttle response after shifting to hi range
Discussion in 'International Forum' started by jd650, Dec 28, 2023.
