05 9400I 52 in sleeper leaking into bunk
Discussion in 'International Forum' started by hd99_fatboy, May 7, 2011.
  1. hd99_fatboy
    hd99_fatboy Light Load Member
    124
    5
    Dec 19, 2010
    carmel, ny
    sleeper leaking water into bunk when it rains, left hand side behind driver seat. seems to be coming from along the shelf on back side of bunk, have a wardrobe cabinet, where it meets the shelf water comes in somewhere around there.
    I've caulked everything I can think may allow water in on the back of the truck, above and below seams of drip edge, bolts, hand rails and such.
    is there anything I can do to try and locate this leak, aside from tearing out the interior?
    Or any known leak points I can check?
    thanks in advance
    Buster
  3. Heavyd
    Heavyd Road Train Member
    7,764
    6,203
    Feb 4, 2009
    Check for cracks in the caulking along the drip rail. Check for and cracks around the bolts that hold the air shield in place, or you may have to remove the ones on that side and reseal them. The water is probably leaking in from somewhere no too far away and tracking inside the seams.
    double yellow Thanks this.
  4. hd99_fatboy
    124
    5
    Dec 19, 2010
    carmel, ny
    found a crack in the sealant under the drip edge on the drivers side, just in front of the rear air wing, could be the culprit, caulked it, sprayed water on it, not seeing any leak, I'll have to wait for some rain before I'll know for sure.
    thanks for the come back Heavy D.
    let you know
  5. Heavyd
    7,764
    6,203
    Feb 4, 2009
    Water doesn't always leak straight down. It will seep along edges and flow in a path that sometimes doesn't make sense. This is especially true with wind driven rain water on a vehicle. I hope that fixes it!
    Strider and hd99_fatboy Thank this.
  6. hd99_fatboy
    124
    5
    Dec 19, 2010
    carmel, ny
    ya I'm thinking this is whats going on, doesn't seem to be anything in the back that would let water in, or where it's showing up anyway. so the crack along the side drip edge is the only place I could find that may.
    now just waiting for the rain...
    as crazy as that sounds...
    thanks HeavyD
    Buster
  7. Heavyd
    7,764
    6,203
    Feb 4, 2009
    You need rain? Just let me wax my car again, it will rain with in 12 hours, bet on it!!! LOL!
  8. hd99_fatboy
    124
    5
    Dec 19, 2010
    carmel, ny
  9. hd99_fatboy
    124
    5
    Dec 19, 2010
    carmel, ny
    well you must have waxed the #### outta your car dude, cause it rained buckets the last few daze. hahaha
    and no leak
    guess that was it. under the drip edge, small crack...
    viola, fixed !
    thanks for the input HeavyD
    always appreciated.
    Buster
  10. Heavyd
    7,764
    6,203
    Feb 4, 2009
    Glad to help!!!
    hd99_fatboy Thanks this.
