05 9400i with c15 acert cranks but no start
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by jpallen, May 22, 2021.
  1. jpallen
    jpallen Bobtail Member
    4
    May 22, 2021
    I’ve got a 05 IH 9400i. I dropped trailer and parked it in front of my shop. Was running fine. I went to start it 2 days later and it will crank like never before but no start. it has 4 new batteries all connections are clean. All connections look good at starter. Have fire to ecm. When I turn the key on I get no check engine light and the high water temp and low oil pressure lights blink constantly. Also after guages sweep they’ll go to 6 o’clock position and stay there while cranking. I pulled rear ecm plug. I have constant power to 48 53 63 65 67. I gain 52 and 70 with key. I thought 63 65 and 67 are grounds and 52 was supposed to be a constant. I’m confused. I’m not electrically inclined but I do 90% of my work. Just wondering if anyone has any insights on this. All my fuses are good I’ve checked key switch and gauge clusters for chaffed wires and bad connections. Any help would be much appreciated
  3. Lazer
    Lazer Road Train Member
    1,825
    2,908
    Jan 22, 2017
    Any smoke coming out the stack when cranking?
    Are you sure you are not out of fuel?
    Magoo1968 Thanks this.
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    CK. lt with a small shot of spray start just to see if fires up for a sec., if it will not start and keep on running after the spray can you have to go back to wires from batt. to fuse to wires leading to ecm. and ck them ground and power, the crankshaft has two sensors 1 behind and 1 under the air comp. can go bad and not throw a code, and motor will not run when one goes bad?
  5. joey8686
    joey8686 Light Load Member
    131
    154
    Jul 1, 2014
    Sounds like no power to ecm if no check engine light when turn the key on, check ecm fuse and terminals
  6. A5¢
    A5¢ Medium Load Member
    389
    544
    Oct 30, 2017
    I had a similar issue that turned out to be the ignition fuse. I looked at it and it looked good. I checked it with a multimeter and it showed me different. This may not your issue, but it's easy, fast and cheap to see.
    joey8686 Thanks this.
  7. jpallen
    4
    May 22, 2021
    Was a broken ground wire that comes from battery. All good now. Was friggin frustrating but I found it
  8. Kgudriq
    Kgudriq Bobtail Member
    5
    im having the same problem
