05 Argosy has non stop beeping noise
Discussion in 'Freightliner Forum' started by teresa5658, Nov 18, 2012.
  1. teresa5658
    teresa5658 Bobtail Member
    Lodi, CA
    I have a 2005 Freightliner Argosy, that has a non stop beeping noise, what could it be? There are no lights on dash and the doors and stairs are shut all the way.
    I would appreciate any help.
    Thank you
    Teresa5658
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    any message on screen?
    what did you do before problem appeared? any works in trash area? driving rought roads? where are you from? argosy is a rare truck here, usually wight ex-swift trucks converted to BDF container haulers
  4. teresa5658
    Lodi, CA
    I am from California, our driver is on his way to MT, no trash area, no rough roads. He woke up this morning and hit the road and the beeping started. He thinks it might be the steps. I also found on another forum that if a tail light is out it will continue to beep also. So he is going to check those things out and get back to me later.
  5. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    if you got argosy with dashboard like in Century Class = beep sound combined with message ore light.
    I sugest stuck air pressure switch in swithc manyfold ore step lock ore cab lock switch.
  6. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    rise cab and drop it back. sometimes helps
    teresa5658 Thanks this.
  7. ralph
    ralph Road Train Member
    1,112
    632
    Mar 1, 2009
    At The Key Board
    Make sure everything is stowed properly OR you will need a new windshield!
    x1Heavy and teresa5658 Thank this.
  8. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Right (Blue) Connector #2 Pin Assignments
    Number Pin Assignment Wire
    C3 Optional Gauge Type 2D (-) '
    C4 Rearmost-Axle Oil Temperature Sensor (-) 43G
    C5 Forward-Rear-Axle Oil Temperature Sensor (-) 42G
    C7 Gauge Return (AU07) '
    C8 Gauge Return (AU08) '
    C9 Gauge Return (AU09) '
    C10 Gauge Ground (AU06) GND
    C11 Gauge Power (AU06) '
    C12 Gauge Power (AU07) '
    C13 Gauge Power (AU08) '
    C14 Gauge Power (AU09) '
    C15 Ignition 437A
    C16 Chassis Ground GND1
    D1 Air Bag 454L
    D2 Optional Buzzer C Power '
    D3 Optional Gauge Type 2D (+) '
    D4 Rearmost-Axle Oil Temperature Sensor (+) 43
    D5 Forward-Rear-Axle Oil Temperature Sensor (+) 42
    D6 Transmission Fluid Temperature Gauge (-) 30G
    D7 Transmission Fluid Temperature Gauge (+) 30
    D8 Optional Gauge Type 2E (-) '
    D9 Optional Gauge Type 2E (+) '
    D10 Optional Gauge Type 2F (-) '
    D11 Optional Gauge Type 2F (+) '
    D12 Optional Gauge Type 2G (-) '
    D13 Optional Gauge Type 2G (+) '
    D14 Optional Buzzer D '
    D15 Ignition Jumper (see LH-D15)* 437A
    D16 Ground Jumper (see LH-D13)* GND
    A1 Optional Indicator 7 '
    A2 Optional Indicator 6 '
    A3 Tractor ABS 376L
    A4 J1708(+) #1 Jumper (see LH-A10)* 1708+1
    A4 J1587+C
    1587+C
    A5 J1708(-) #1 Jumper (see LH-A10)* 1708+1
    A5 J1587-C
    1587-C
    A6 Panel Lights 29A
    A7 Buzzer Enable Jumper (see LH-B12) 437Z
    A8 Starter Lockout 15D
    A11 Battery 437
    B1 Right Turn 38R
    B2 Headlights (high beams) 20H
    B3 Low Air Pressure 18
    B4 Wheel Spin 376S
    B5 Fuel Level (+) 47
    B6 Fuel Level (-) 47G
    B11 Battery Jumper (see LH-D14) 437
    Left (Pink) Connector #1 Pin Assignments
    Number Description Wire
    A9 Washer Level 320A
    A10 J1708(+) #1 Jumper (see RH-A4)
    1708+1
    A11 J1708 Databus (+) #2
    1708+2
    B1 Keypad Panel Lights 29A
    B2 J1708 Databus (-) #2
    1708-2
    B3 J1587 Databus (-) 1587-C
    B4 ACPU (-)
    1587-P
    B5 Wire 3 (keypad) 437D
    B6 Wire 2 (keypad) 437C
    B7 Wire 5 (keypad) 437F
    B8 Wire 1 (keypad) 437B
    B9 Wire 4 (keypad) 437E
    B10 J1587 Databus (+) 1587+C
    B11 ACPU (+)
    1587+P
    B12 Buzzer Enable 437Z
    Use this list to find Buzzer actuation wire. It is easy using DVOM to find what buzzer pin is grounded.
    As you can see there are optional Buzzer inputs, that actuate Buzzer w/o text warning and indicator light
    x1Heavy Thanks this.
  9. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,161
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    Or in plain English...
    Does it have a low voltage disconnect and warning on the rig? If so, it's normally behind the passenger side panel, right by the passenger seat. See if the noise is coming from there.
    Martin
  10. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    ouh, LVD switch unit is located in right side of cab, really)))) Instrumental cluster beeper is built in cluster
  11. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    BTW, about beep sound. Many Argosy trucks were used by SWIFT and retired converted to 20' container haulers + European trailer and Swift used dataloger ore something like this hidden in sleeper. They remove it but datalink and CAN wires not. and when this wiring is short instrumental cluster beeeps
