05 columbia mirror doesn't heat up
Discussion in 'Freightliner Forum' started by chimbotano, Dec 9, 2016.
  1. chimbotano
    chimbotano Heavy Load Member
    792
    1,140
    Apr 21, 2013
    My mirror of passengers side doesn't heat up. Would you please help me to diagnostic the problem? I can't find the fuse, if the right side mirror has a fuse.
    Thank you for your help.
  3. Pnwtrucker
    Pnwtrucker Medium Load Member
    383
    821
    Nov 5, 2016
    Look at the end of your hood it says freightliner! That's your problem
    chimbotano Thanks this.
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Pull the switch to see if power is at the switch then when switch is flipped on if power is going to heater, then ck at door for power at glass, if power is getting into glass you will need to buy a new heated glass mirror
  5. chimbotano
    792
    1,140
    Apr 21, 2013
    LOL, most likely......that is the problem !!!!!!!!!!!
